Trying to join two objects
I want to join two objects, and I just don't get it.
I have two books, Propeller Manual, and Propeller Education Kit Labs: Fundamentals.
But I still don't get it.
I want to have both programs run at the same time.
what I would like help with at this moment is getting both to run at the same time
and the name of the four variables that carry the four Fahrenheit temperatures from the
" modified_ds1822_6-1-15" object, that I will be trying to incorporate into the
" _ml_graphics_demo_v02" object.
Thanks in advance
Bill S.
Thanks in advance
Bill S.
Sorry I can't be more specific but I cannot read/decompress the attached file or find the objects in the OBEX.
'================================================================== PUB Main_Program | index1, index2, inc1, inc2 , A_Val, B_Val, indicator1, indicator2 '================================================================== 'This is the main object in the running program that generates the values to display initialize Indicator1 := 2 Indicator2 := 516 index1 := 100 index2 := 10 Inc1 := 5 Inc2 := 4 ' A_Val := 100 'B_Val := 100 repeat ******************************************************************************************************** ' REPLACE THIS SECTION OF CODE WITH CODE THAT READS THE TEMPERATURE ' AND SET INDEX1 TO TEMPERATURE1, INDEX2 TO TEMPERATURE2 index1 := index1 + Inc1 if index1 > 600 Inc1 := ( -5 ) Indicator1 := 2 elseif index1 < 3 Inc1 := ( 5 ) Indicator1 := 1 index2 := index2 + Inc2 if index2 > 600 Inc2 := ( -4 ) elseif index2 < 3 Inc2 := ( 4 ) ********************************************************************************************************* A_Val := index1 B_Val := index2 DiaplayGauges( A_Val, B_Val, indicator1, indicator2 ) ' waitcnt(clkfreq + cnt)I downloaded your attachment and got 7 zip to decompress it this time, so I could look at the code. This should point you in the right direction. Sorry, no hardware atm to test with.Use the Graphics demo code as your main program and replace the code indicated above with the code from the modified ds1822 object that reads the temperature. You will need to add the 1-wire object to the Graphics demo.
