Function Calculation
Anyone know how to find the exact function for this sequence?
0 1
1 2
2 2
3 3
4 3
5 3
6 4
7 4
8 4
9 4
10 5
11 5
12 5
13 5
14 5
15 6
16 6
17 6
18 6
19 6
20 6
21 7
22 7
23 7
24 7
25 7
26 7
27 7
28 8
29 8
30 8
31 8
32 8
33 8
34 8
35 8
36 9
37 9
38 9
39 9
40 9
41 9
42 9
43 9
44 9
45 10
46 10
47 10
48 10
49 10
50 10
51 10
52 10
53 10
54 10
I've found the function: floor(sqrt(x*1.799))+1 to be a close fit. However, I don't think that's quite right. The sequence is easy enough to see... (y repeat an incrementing number of times) but, I can't seem to figure out the exact equation.
0 1
1 2
2 2
3 3
4 3
5 3
6 4
7 4
8 4
9 4
10 5
11 5
12 5
13 5
14 5
15 6
16 6
17 6
18 6
19 6
20 6
21 7
22 7
23 7
24 7
25 7
26 7
27 7
28 8
29 8
30 8
31 8
32 8
33 8
34 8
35 8
36 9
37 9
38 9
39 9
40 9
41 9
42 9
43 9
44 9
45 10
46 10
47 10
48 10
49 10
50 10
51 10
52 10
53 10
54 10
Not sure if that is helpful or not....
Doh! this should work: y =Ceiling( (SQRT(1+8 * ( x +1)) -1) / 2 )
-Russ
You can do this with integer math...
Y = 1+((N/1)/(N/1))+((N/3)/(N/3))+((N/6)/(N/6))+((N/10)/(N/10))+((N/15)/(N/15))+((N/21)/(N/21))+((N/28)/(N/28))+((N/36)/(N/36))+((N/45)/(N/45))
y := Floor((sqrt(1+8x)+1)/2)
Is perfect!!! How did you guys figure that out? Also, there's another part I need help with:
x, y
0: return 0; (count down from 1)
1: return 1; (count down from 2)
2: return 0; (count down from 2)
3: return 2; (count down from 3)
4: return 1; (count down from 3)
5: return 0; (count down from 3)
6: return 3; (count down from 4)
7: return 2; (count down from 4)
8: return 1; (count down from 4)
9: return 0; (count down from 4)
10: return 4; (count down from 5)
11: return 3; (count down from 5)
12: return 2; (count down from 5)
13: return 1; (count down from 5)
14: return 0; (count down from 5)
15: return 5; (count down from 6)
16: return 4; (count down from 6)
17: return 3; (count down from 6)
18: return 2; (count down from 6)
19: return 1; (count down from 6)
20: return 0; (count down from 6)
21: return 6; (count down from 7)
22: return 5; (count down from 7)
23: return 4; (count down from 7)
24: return 3; (count down from 7)
25: return 2; (count down from 7)
26: return 1; (count down from 7)
27: return 0; (count down from 7)
28: return 7; (count down from 8)
29: return 6; (count down from 8)
30: return 5; (count down from 8)
31: return 4; (count down from 8)
32: return 3; (count down from 8)
33: return 2; (count down from 8)
34: return 1; (count down from 8)
35: return 0; (count down from 8)
36: return 8; (count down from 9)
37: return 7; (count down from 9)
38: return 6; (count down from 9)
39: return 5; (count down from 9)
40: return 4; (count down from 9)
41: return 3; (count down from 9)
42: return 2; (count down from 9)
43: return 1; (count down from 9)
44: return 0; (count down from 9)
45: return 9; (count down from 10)
46: return 8; (count down from 10)
47: return 7; (count down from 10)
48: return 6; (count down from 10)
49: return 5; (count down from 10)
50: return 4; (count down from 10)
51: return 3; (count down from 10)
52: return 2; (count down from 10)
53: return 1; (count down from 10)
54: return 0; (count down from 10)
etc.
Basically, I'm counting down from "y := Floor((sqrt(1+8x)+1)/2)" using x. I think the solution involves some modular arithmetic, but, I don't know.
In your second request ... calculate Y first as before ...
... Then use Y as a Modulus function against X to get the return value you are requestng
The answer is more complex than:
val := x % y
In the lookup table above, using such a function fails after the first values. Adding a constant offset too x is not a solution either. I think some kind of offset based on y needs to be added to x before the mod.
Still can be solved with integer math... here is a Basic Stamp II program that shows the result.
Where Z is the input variable
Y is the first requested Output
Z is the second requested Output
' {$STAMP BS2} ' {$PBASIC 2.5} X VAR Byte Y VAR Byte Z VAR Byte FOR X = 0 TO 54 Y = ((X/1)/(X/1))+((X/3)/(X/3))+((X/6)/(X/6))+((X/10)/(X/10))+((X/15)/(X/15)) Y = Y +((X/21)/(X/21))+((X/28)/(X/28))+((X/36)/(X/36))+((X/45)/(X/45)) + 1 Z = (Y-((X + ((1-(Y & 1))* Y>>1)) // Y))-1 DEBUG DEC X,TAB, DEC Y,TAB,TAB, DEC Z,CR NEXTI can try to explain how I did it.
Think about the series 1 + 2 + 3 + 4 etc... In your y column the number of 1's is 1 and 2's is 2 and 3's is 3 and so on. So the total number of terms in the Y column for a given number is the sum of that series. The number of terms is also the X column (except shifted by one).
For example, the number of terms for Y =4 is 1 + 2 + 3 + 4. Thanks to Wikipedia, one can find the sum of such a series as n(n + 1) / 2. That's great if you want to get from y to x. For your case, you can use the quadratic equation to solve x = y ( y + 1) / 2 for y. You'll get y = ( sqrt (1 + 8x) - 1 )/ 2.
Once you get that far, the rest is probably more obvious. You only get integer numbers for y if x is at the end of a series of repeating numbers. Screwing around with floors and ceilings addresses that. I subbed in x-1 for x to shift everything to account for starting at zero.
This code is not actually for running on the propeller/basic stamp. I asked the above questions because I was trying to implement a parallel bitonic merge sorter in hardware. See this random homework assignment for details: http://web.mst.edu/~ercal/387/P3/pr-proj-3.pdf.
I was trying to implement the algorithm using generate statements in system verilog and I was running into a bunch of issues that prevents me from just doing:
int; l = 0; for(int i = 1; i <= D; i++) begin for(int j = (i-1); j >= 0; j--) begin for(int k = 0; k < (1 << D); k++) begin end l++; end endSo, I was trying to turn the loop inside out by just having on variable increment and compute the rest of the loop from that.
However, the verilog synthesizer refuses to do anything once it finds any $floor or $sqrt functions and just quits on that. So, with even the above, I had to figure out another way.
I did manage to get the code working without having to hard code anything however, the solution was not to use any generate statements and just to put everything into a always block where you can use complex variable assignments.
@tranger - I see. Really good math skill there.
