Bit Operations in Spin
I wrote following code. But the result is little odd as commented below; it looks the data is larger than 16 bits..? Could someone explain this? Thank you.
Oh, the object I used here may not work though.. So please just put spaces at the object name and delete usb.newline. Or, use other serial object...
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
obj
usb : "ParallaxSerialTerminal.spin"
VAR
word x, one, zero, r, temp
PUB main
usb.quickstart
x := %1111_1111_0000_0101'_1111_1111_0000_0101
one := %1111_1111_1111_1111'_1111_1111_1111_1111
zero := %0000_0000_0000_0000'_0000_0000_0000_0000
temp := %0000_0000_0000_0000'_0000_0000_1111_1111
'r := x >> 8 << 8 ' outcome is as expected, 1111_1111_0000_0000
r := x << 8 >> 8 ' outcome is NOT as expected, 1111_1111_0000_0101
' I expected 0000_0000_0000_0101
repeat
usb.clear
usb.bin(r,32)
if (r>0)
usb.newline
usb.str(string("Least significant byte of x equlas 1"))
else
usb.newline
usb.str(string("Least significant byte of x NOT equlas 1"))
usb.newline
waitcnt(cnt + clkfreq/10)
CON
obj
VAR
PUB main
usb.quickstart
repeat
usb.clear
usb.bin(r,32)
if (r>0)
usb.newline
else
usb.newline
usb.newline
Also,
Some of the operations only work correctly on longs.
so the intermediate result of the first shift is written into the 16bit variable.
Andy
or, more simply:
