Opamp/Circuit Recommendation?
JonnyMac
I need to bump a 0-to-5v signal by 2.5 volts so the output is 2.5v to 7.5v. The Propeller side of things has the 5v supply; the other device can provide ground, 2.5v, and 7.5v.
I'm open to suggestions!
Thanks.
Thanks.
Other selection numbers are offset & drift and bandwidth, and price...
You need an op amp summing amplifier: http://www.electronics-tutorials.ws/opamp/opamp_4.html and a source of 2.5 volts.
Assuming your devices have a common ground and your power rails have enough head room I'm sure you can work it out.
Warning: I have never done this but my confidence in op amps is great
FF
Some of the older med tv systems used to use an inverting level shifter to essentially shave off the dark current signal from the actual live TV signal. Dark current would be sampled when x-ray was off, and subtracted when x-ray was on.
Will go find it now.
And to you as well Sir.
Thank you for that TI publication "Op Amps for Everyone" tip.
It is pure gold!
Elliot Sound Products has IC boards for a versitle use of a 4x op amp that may keep the cost down. In this case you might only use one side of it (just 2 stages, intended for stereo preamp).
sound.westhost.com
I know you may be thinking this is overkill, but it is just about the only good mail order source for op-amp project IC boards.
These days it is actually harder to buy a 1x op amp IC than a 2x or a 4x. Elliot Sound Products Project 88 board can pretty much adapt to any project.
http://sound.westhost.com/project88.htm
It can be this simple
+5V | .-. | | | |100k '-' | ___ | |\ 0~5V---|___|--o-----|+\ 50k | >---o------- 2.5~7.5V .---|-/ | | |/ | | ___ | o---|___|--' | 50k .-. | |100k | | '-' | GNDHere is a nice article, full of juicy maths, explaining how that works:
http://masteringelectronicsdesign.com/the-transfer-function-of-the-summing-amplifier-with-n-input-signals
Testing it out now. Op amps like to keep their + and - inputs the same voltage. So plugging in some random input voltages, and the output voltages seem to work out right. A cunning circuit!
http://www.pmillett.com/opamp_pcb.html
Ebay has a few others, but I am not willing to investigate all the pros and cons of each board.
Thx
frank
The vast majority of op-amps are intended for dual voltage supplies and provide better gain and better linearity if +15V/-15V supply is provided.
So working with a single sided supply and in a lower voltage range is going to mean researching a specialized op-amp. It also may mean that the need for multiple stages to get the right amount of gain should be considered. (The Art of Electronics, 2ed by Horowitz, et al does have a selection table for op amps, but I fear that is a bit old and out-dated.)
So an output swing from 0 to 7.5 Volt DC is less than ideal for many op-amps. It may even be better to use a digital device that is similar to an op-amp - a comparitor. For those not aware of it, many comparitors are willing to operate far beyond the +5VDC for the sake of providing a higher voltage output.
In my experience, using an op amp for a digital frontend creates more work than is necessary. Considering a comparitor might make the whole design cleaner - (a) the device is intended for a single voltage supply, (b) hystersis is easier to deploy.
How on Earth is a comparator supposed to translate an input of 0-to-5v to an output of 2.5v to 7.5v ?
This is not a digital requirement and I'm sure hysteresis is not desirable. Mind you JonnyMac has not said exactly what he want's to do with this only given us an abstract problem.
There must be a ton of rail to rail single ended supply opamps that can do this now a days.
You just need to make absolutely sure that the grounds do not connect through any other circuit.
Bean
Okay, I misunderstood the original goals were not a conversion to an digital input.
It still remains a rather special op-amp as most use a greater voltage range than 5 volts to provide better gain, roughly a range of 24-30V and usually dual supply.
Rail to rail single suppy op amps tend to be the less common product, not so much demand. Not impossible to locate, but more less to choose from and maybe more expensive.
I completely disagree ... Most Op-Amps can be configured for single or dual supply by how you externally supply the voltage to them. To the Op-Amp all it "sees" is a relative voltage to it's supply pins... And as far as rail to rail versions, they are easier to find as well.
Argh... I was intrigued by your post Duane, but the link seems broken in the new forum. I'd tried searching for this on YouTube but couldn't seem to find the video... any new links are appreciated!
I'm guessing Jon is not working at that level and could get away with something a lot cheaper and easily available.
That video is well worth a watch though and is here:
