SimpleIDE, C: Counting milliseconds — Parallax Forums
ptiagoptiago Posts: 37
edited 2015-06-19 12:56 in General Discussion
Hi,
Probably the question is not new...
I need to count the milliseconds, and i would like to be efficient and reliable.
I made a simple C program to test (attached).
To make it short: this is the method executed in a cog:
volatile static unsigned long millis=0;
void countMillis(void *par)
while(1)
millis++;
waitcnt(CLKFREQ_1000 + CNT);
this is the code to measure the 1sec waiting
ts1 = millis;
waitcnt(CLKFREQ + CNT);
ts2 = millis;
the delta (ts2-ts1) is 992/993 ms, there is a gap of 7 to 8 ms, countMillis, performs two sum operations and the measure code one sum operation plus the assigning variables etc.
what i can do minimize the gap, or to obtain the most realist milliseconds counter ?
Tiago
    edited 2015-06-19 12:39
    To eliminate the loop overhead and the time used by millis++ you can do the following
      int count = CNT;
      while(1)
        millis++;
        waitcnt(count += CLKFREQ_1000);
  • ptiagoptiago Posts: 37
    Dave,
    Thanks, it works !!!!
    1000 ms, in all the cogs at same time.
    Tiago
