Erco, here's the cheap MP3 modules!
I've seen these things already - they are cheaper than the traditional VS1011, and they used the traditional UART interface instead of the SPI.
http://www.ebay.com/itm/UART-Control-Serial-MP3-Music-Player-Module-For-Arduino-AVR-ARM-PIC-/311133945527?pt=LH_DefaultDomain_0&hash=item4871073eb7
Pop in a microcontroller, the whole module does it for you! You only select which file to play and et cetera. SD-Card functions and MP3 decoding are all done inside the module.
Want a talking alarm clock? No need SD-card, just "upload" MP3 files inside, no need programmer too!
http://www.ebay.com/itm/BY8301-16P-SSOP2-MP3-Aduio-Serial-Voice-SPI-FLASH-Module-3W-Amplifier-Micro-USB-/271684522808?pt=LH_DefaultDomain_0&hash=item3f41a8d338
However, the product page isn't all clear - is it the 16 megabyte or 128 megabyte flash? Looks like you can squeeze in a few low-res MP3 inside for some talking applications etc.
http://www.da-share.com/misc/catalex-mp3-board-yx5300-chip/
zip file: http://www.da-share.com/files/datasheets/Catalex_YX5300_Docs.zip
Also forum discussion here http://www.thebackshed.com/forum/forum_posts.asp?TID=7319 - talks about issue playing small files
Docs say micro sd <= 2gb and micro sdhc <= 32gb
I've never found the generic MP3 player all that useful in robotics, other than a robot that plays random music and sounds as it rolls along. Though pumping data into a VS1011 can be taxing (the Propeller can do it and still have headroom for other tasks), it's really what you need if you want to synchronize the sound playback with a robot function. Since you're managing the data bytes, you know exactly where you are in the sound clip, and your programming can use clever timing to synchronize those with events.
I suppose another alternative is to play monaural sound, and use the other side for a data track. I've never done that, but I imagine it's within the realm of possibility.
I'd be interested in an imported version of this (doesn't have to be a shield, just SPI from Flash to feed the data): https://www.sparkfun.com/products/10628
I don't troll eBay very much these days. Anything decent along those lines out there?
https://learn.adafruit.com/adafruit-audio-fx-sound-board
Piping MP3 (or WAV or OGG) data to a VLSI or similar chip isn't all that hard. SPI is rudimentary, and all these chips have a "gimee more data" pin that tells the MCU when to send out a burst again. There are SPI and SD libraries that do the heavy lifting. It's prerty much just a question of an MCU waiting for the Ready pin to change to send another burst.
On the Arduino the processor is occupied at least 50% of the time processing this data, depending on the data rate. You want nice sound, of course, so you encode at a bitrate that gives you the quality you need. The higher you go, the more data that has to be shuttled from MCU to sound chip, and the less time the Arduino has for anything else.
Enter the Propeller. Just use one or two cogs to send data to the sound board, and you still have cogs left over for checking button presses, pinging the odd ultrasonic sensor, or flashing LEDs. Most of the MCU-driven MP3 boards are shields, which just add to the size. One of these 24-pin form factors would be ideal.
Speaking of sound projects, I just dropped off a toy model to a client an hour ago. It needed a sound chip. I was about to build a chiprecord board and amplifier when I found a $6 toy that had a suitable sound in it. I figured I still needed an amplifier for the volume I needed, which is a pain, cuz then I need another micro pin to turn the amp on & off. Much to my surprise, the toy sound chip had plenty of volume once I put a decent sized speaker on it. The speaker in the toy was only 3/4" diameter yet put out surprising sound.
Could I be you? I mean, the highlight of my day is taking my dog to the McDonald's drive-thru and sharing a breakfast burrito with her.
The EFX-TEK AP16+ is a good example of making a WAV player with triggers and custom control with the Propeller: http://www.efx-tek.com/topics/ap-16.html
I liked this one from Sparkfun because of the mixing capabilites: https://www.sparkfun.com/products/13660
Not sure how easy it would be to have the prop mix more than one WAV file into a single output. I would think a few WAV files could be blended reasonably easy. Just start/blend another WAV object right?
Jon shared some code he developed (I think for the EFX-TEK) but it didn't agree with the library I was using at the time. I'm not enough of a PASM guy to know how to merge the two.
Anyway, yes, WAVs are good, too. But for some reason people have this aversion to the format, even though it's clean and crisp and clear (we have SD cards that arte plenty big to hold the files). All their stuff is MP3.
No problem man! Glad you liked these as well!
Some years back I built an SD-Card Wave file player, using a cheap DIP format PIC32. Worked pretty well.
But at a cheaper price I can replace all that with that module. And less time worrying about the FAT32 drivers for the microcontroller.
I never experienced any pop and I don't recall if it was because I used updated code or if I got lucky. My setup was a Prop-BOE with the line out connected to a set of powered computer speakers and subwoofer. It was paired with a digital I/O board to control some LED strips and muffin fans. My code zip is attached along with a couple pics.
More details of the project are on this thread: http://forums.parallax.com/showthread.php/152388
Here are two YouTube videos of the project and one has good audio of the keypad entry sequence. The other video has a lot of background noise from the other people and kids that were in the sanctuary when I was filming. I had intended on re-shooting video by myself after the play, but didn't get a chance. I still need to put the entire project write up onto the forums.
This is the Time machine jumping from 2013 to 1978
http://www.youtube.com/watch?v=QYMjnMPeGqU
This is a keypad entry sequence where the month and day are entered, but no year (thus causing part of the problem of the time machine jumping to random years)
http://www.youtube.com/watch?v=EyhqAzLbkiE
http://www.ebay.com/itm/191583556799
I do now remember I did this with a pre-release version of the Prop-BOE. I don't recall revisiting WAV file playing with the release version of the board that I now have.
