PropellerIDE 0.30.1 for Raspberry Pi installation issues
I could not find a working set of compiled qt5 packages anywhere for PropellerIDE
https://github.com/parallaxinc/PropellerIDE/releases/download/0.30.1/propelleride-0.30.1-armhf.deb
Elf is compiling Qt5 from source right now... and for the next few hours, hopefully that would work.
Can Parallax either:
- make a statically linked (against qt5) version of PropellerIDE
- have qt5 packages used with a release available for download
Granted, I have not developed with Qt for years, but new Propeller users should not be expected to hunt around and compile such a large set of packages as Qt to be able to run Propeller IDE.
p.s.
PropellerIDE installed without a hitch on Ubuntu 15.04 on one of my x86 boxes
p.s.
Here are the steps I've been following since March or so:
You need to do part A so you don't need to build a QT on your RasPi.
Will try it today.
Elf is compiling Qt5 right now, and I don't want to interrupt him.
Perhaps there is something that needs adding to the install instructions for the Pi.
program to load to ram and run. But trying the EEPROM it always comes back with a bad checksum error.
Interesting. Which Propeller board ( or is it Prop Plug? ) and presumably you're using Propman to do the upload?
and run the program. But I was never able to burn the EEPROM. The new installation was using Propman. IIRC before the bad checksum error I thought I saw something about
GPIO 17 go by? That board has it's own USB connection.
