How to mix 2-composite video signals onto TV screen?
There must be a simple gadget that does PIP (picture-in-picture) from 2 different video sources.
For example - to play a video game (composite signal 1) while having a CCTV camera (composite video 2) displayed in say upper right TV screen corner.
Any ideas where to find it?
John
John
The sources you mention - a video game and a CCTV might have entirely different scan rates and resolutions.
So, instead of a gadget, how about a laptop? Doesn't have to be a high-end model. And instead of a CCTV camera, could a USB Webcam work instead? From your description, this sounds like a player inset over a video game screen, common on player channels found on YouTube and Twitch. They don't use gadgets, just some software (some of them write it themselves).
If your sources must be composite video, there are still converters to get it into digital form, and once again you're in the realm of doing the PIP digitally.
Couldn't locate any cheap $10 items as all I was able to find cost close to $200 as in http://www.ambery.com/2pivigemi.html.
The idea is to play a video game while keeping an eye on baby monitor in upper 1/8 corner of the same TV
Way back when I was an assistant teacher for video classes we used to use video special effects generators for this. They could do PIP and a lot more. Check ebay, there are a lot of used ones there for cheap.
http://www.ebay.com/itm/New-Everfocus-Everplex-8BQ-EP100-E-B-W-Dual-Page-Quad-Video-Processor-/321771729062?pt=LH_DefaultDomain_0&hash=item4aeb16f0a6
Perfect - I'm going to order it!
Wouldn't this be full screen or 1/4 screen per input only? I don't recall any of these doing actual PiP but I've only worked with the cheap ones, which weren't cheap back in the day.
You're aware that it's for black and white, right? That's what the B/W stands for. These are for security cameras, which used to be black and white. Now that they use color, quad adapters like this are pretty cheap, because no one uses them.
Also, you probably won't get to change the PIP. On models like this you always get either a full screen, or the quad screen. You have two inputs, so they will fill just two quarters of the screen.
Seems to me the $200 processor sounds about right. But for that price, you could probably pick up a second hand LCD TV, 35" or maybe a little larger, that already has multiple inputs and built-in PIP. The older ones still supported composite video. I gather your TV is an older model that has only one input.
Erco's suggestion is also pretty good. Get a small portable, place it beside your TV.
https://www.youtube.com/watch?v=oF-gTy16p8c
$26, plus it comes with a camera lol. That's nuts!
That is nuts!
May just have to order one. Not sure what "Map" you going to get. Surely not an up to date US map.
(I have a business friend in Valencia. Maybe I could write the whole thing off as a business expense...)
Same product on sale on Amazon ($160) has a lot of negative reviews. But, for hacking, it looks like it's got some nice parts.
From the same manufacturer, but at a mild $105.
Take a look at the specs (up to four composite video inputs, several PIP arrangements, configurable video loss detection and video motion detect, buzzer alarm)
http://www.ambery.com/pivipr.html
I hope it helps a bit
Yanomani
Sigh....All sold out before I ordered:
http://www.ebay.com/itm/261907042384?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true
Nice find, still more than a cheap LCD but you get real PiP, color and motion based alarm outputs!
I'm guessing that it's a scam. Look at the ratings of the seller and the 'buyers' of other products. Also this same item is all over ebay for around $150.
For an LCD screen and backup camera, it's worth the eBay price, especially since the price includes shipping.
