Are you cut out to work at facebook? group these anagrams in SPIN
tonyp12
Don't Google the answer/the angle of attack.
During a 45minute Facebook job interview you could be requested to write a C++ from scratch that does this:
You have a list of these words
"tsar", "rat", "tar", "star", "tars", "cheese"
re-arrange them so the anagrams (words that have the same letters) are grouped together.
output order not important.
I'm trying to understand how these sentences go together. If you've just fired the hiring manager, then you're their boss right? If you've the hiring manager's boss why are you leaving contact information? Are you leaving work early by walking out the door?
Or are you placing yourself in the position of the person at the interview and showing Facebook they should hire you to be the hiring manager's boss? I'm confused, which is not uncommon after you've made a post but generally my confusion arrives from your technical presentation sailing over my head. This time I don't think my confusion is caused by my lack of understanding of the subtleties of inductors. (Don't get me wrong. I'm usually thrilled to be confused by the subtleties of inductors.)
Did I win?
2. G
Nothing in the challenge indicated they are wanting a universal algorithm for arbitrary words, just these -- emphasis on "these words" in the question text.
(You don't even have to count characters if you're going after the literal interpretation of the question.)
I agree that on the surface a test like this seems trivial and useless, but often they are looking for coders who don't overcomplicate the simple.
"G
I noticed that the correct grouping of that list is known simply by the length as well. What ran though my mind is that given the problem description is to ask if that is the only input or is it just an example. If the answer is that it is the only input then I would have explained my solution and expected not to have to fiddle around writing code.
If you are going to short circuit the solution like that you don't even need to compare the string lengths, just write six statements that print the strings in the right order!
If I'm not mistaken "zzzzz" encodes as 101 to the power 5, which is 10510100501, which is greater than the maximum value of an unsigned 32 bit integer. So the G
First you'd need a Propeller cluster to receive data and transmit that data to a second Propeller cluster running an ad server, and a third Propeller cluster running an anagram server that relays anagram data to the second cluster. The third Propeller cluster also sends your data to a fourth Propeller cluster running a dictionary server comparing your anagrams to real words and phrases, and sends dictionary (mis)match information to the second cluster which spams others within about 50 "friends" distant to you with data related to you and your inability to create words that make anagrams and offers programs and FB add-ins that can help those "friends" do better than you....
This was for Facebook, right?
If it ain't in the Official Scrabble Players' Dictionary, it ain't a word, and "zzzzz" ain't in there. By arranging the letters in order of frequency (e-t-a-o-i-n-s ...) and assigning those with the highest frequency the lowest primes you can accommodate the most words with G
then sort and stable_sort are in the standard libraries...
Building a character frequency table for each word avoids the size limit of "Godel coding". Either way
you then have to spot equivalence classes (can again be done by sorting the encodings of the words,
or just by N^2 search for matching entries)
In a hurry I would be tempted to write something inefficent and recursive which is readable and hard
to get wrong:
bool is_anagram (char * a, char * b) { for (char letter = 'a' ; letter <= 'z' ; letter++) if (char_count (a, letter) != char_count (b, letter)) return false ; return true ; } int char_count (char * a, char c) { if (a[0] == 0) return 0 ; return char_count (a+1, c) + (a[0] == c ? 1 : 0) ; }The top level takes a word at a time and picks out all its anagrams, outputing them and striking from the input list.Quora:
Perhaps you are right, "cheese" should be included even though it is not an anagram of anything in that list. The question does say "re-arrange them ..." which implies list them all.
I thought I'd find a strict definition of "anagram". Type that into google and it says "Did you mean: nag a ram"
The ascii codes from each word multiplied together would tell you which words ( groups of letter ) had the same value. tsar, star and tars = 442, rat and tar = 327 and cheese = 621.
During interviews you don't have the luxury of time when giving answers. The paradox is that someone spent quite a bit of time developing the questions.
Sandy
But the program can not just be limited to these specific words, some words may be so long that it will overflow 32bits using that technic
Some words may be using same letter more than once and may come to same total though it's not an anagram of any other word in the list.
That's why I'll probably never work at Facebook. Must have been an interesting experience anyway. I can't imagine that many people get to the interview stage with those guys.
I just did an interview with an organization that are building muon detectors for the Large Hadron Collider. The experience was interesting but I don't think I got the job.
Sandy
The latter of the two is what I was thinking ... "...Or are you placing yourself in the position of the person at the interview and showing Facebook they should hire you to be the hiring manager's boss?"
In almost ALL cases, a question like this at an interview is to see if you know the lingo. Thinking outside of the box is always to your advantage unless you have little to no ambition and are happy answering tech phone calls all day long. Personally not my cup of tea.
So the task proposed ... "re-arrange them so the anagrams (words that have the same letters) are grouped together.
output order not important."
You have to ask yourself, how this would be applied in a practical way? ... Predictive typing and spell checking is immediately what comes to my mind.
So given the words, (assuming they are all words), what must be done here is to create an algorithm that builds a histogram based on the letters in each of the words.
i.e.
take the first word "tsar"
rat - is a 75% letter match
tar - is a 75% letter match
star - is a 100% letter match
tars - is a 100% letter match
cheese - is a 25% letter match
So the FIRST alphabetized grouping would be...
100%
star
tars
tsar
75%
rat
tar
25%
cheese
For the second group, take the word "rat"
tsar - is a 75% letter match
star - is a 75% letter match
tars - is a 75% letter match
cheese - is a 0% letter match
So the SECOND alphabetized grouping would be...
100%
rat
tar
75%
star
tars
tsar
0%
cheese
... and so on for each "word" .... the coding for this is trivial, since it is simple string manipulation. If you are having problems there then perhaps you need to re-evaluate your application in the first place.
However for the remaining words the results for "tar" and "rat" would be the same as well as the same results for "star", "tars", and "tsar" ... and "cheese" is always on his own, just to make sure that a bad apple is detected although the "s" in cheese would give a trace percent for some of the words
... hint, just look at the 100% grouping for the words you have already done, there is no need to re-hash the algorithm each and every time.
t = { "tsar", "rat", "tar", "star", "tars", "cheese", } function id(s) local n=0 for i=1,#s do n = n + s:byte(i,i) end return n end u = {} p = {} for i=1,#t do p[#p+1] = 0 u[#u+1] = id(t[i]) end for i=1,#u do if p[i] == 0 then p[i] = 1 print("===") print(t[i]) for j=1,#u do if p[j] == 0 and u[i] == u[j] then p[j] = 1 print(t[j]) end end end endoutput is:
Yeah, I threw the "id" function together quickly and it accidentally worked for this case.
There's a story that's decades old, and perhaps apocryphal, about a company (variously IBM or some other large firm) "testing" its college grad applicants by giving them a written test. After a short instructional paragraph at the top, it said, "Do not take this test. Put your name on it, leave all questions blank, and sit quietly at your desk." The story goes about 80% of the applicants didn't read the instructions, and filled out the test. They didn't get to the second interview.
The thing is this: Tony's initial description doesn't warrant anything but writing a C++ program where you've manually re-arranged the elements of the array. If that's not demanding enough, you could use a bit of Occam's Razor to come up with the least obtuse result given only the stated instructions. So it's really not short-circuiting, but following directions.
Assuming this Facebook story isn't apocryphal too (and I believe it is), the real instructions are likely more involved. But who knows. Shouldn't a programmer's first job, when faced with uncertain requirements, is to get clarification? Perhaps the correct answer is, "What do you mean exactly?. Please be more specific what the example program is intended to do."
t = { "tsar", "rat", "tar", "star", "tars", "cheese", "mow", "lox"} function id(s) local t = {} for i=1,26 do t[i] = 0 end for i=1,#s do local c = string.lower(s:sub(i,i)) if c >= "a" and c <= "z" then local h = string.byte(c) - ("a"):byte() + 1 if h > 0 then t[h] = t[h] + 1 end end end local r = "" for i=1,26 do if t[i] > 0 then r = r .. string.char(("a"):byte() + i - 1) end if t[i] > 1 then r = r .. t[i] end end return r end p = {} u = {} print("* word -> id *") for i=1,#t do p[i] = 0 u[i] = id(t[i]) print(t[i], u[i]) end for i=1,#u do if p[i] == 0 then p[i] = 1 print("===") print(t[i]) for j=i+1,#u do if p[j] == 0 and u[i] == u[j] then p[j] = 1 print(t[j]) end end end endHere's the output (I also show the string to id table)
Many moons ago, I interviewed for a position at the customer I had been providing onsite vendor support for over the prior 2 years. I was told I wasn't "right" for the position....I don't recall her actual reasons for not considering me as a good candidate. I went back to the customer's site and told my future manger HR's reaction. Within a couple hours, the HR person had received calls from a rather disappointed manager, director and executive director (oh, and her director) that maybe she reconsider her perspective on my interview. She called back and confirmed I could start on the previously agreed upon date. Twenty seven years later, so much for HR and interview process.
As for the Facebook question, sprinkle some random advertising in your output and suggest how they can send the collected user data to one of their "big data" lakes and monetize it and I'm sure they'll love you!! (Maybe I feel the same about Facebook as I do about HR interviews!)
Here is some more info:
http://sahandsaba.com/interview-question-facebook-anagrams.html
Depending what language you get to use, it would be pretty hard to write one in 10minutes if you are not pro in string sorting.
In SPIN it's very hard as there is no run time allocating of new arrays and strcomp and strsize are the two only string commands available, everything else has to be done byte by byte.
SPIN rules: All words are in lower case already, random words, length and amount (could even be external file with no visual idea how many there are)
The list is just a zero delimited byte array ending with 13 or use the address of listend as match
use "Parallax Serial Terminal.spin" to output the words, you are allowed to trash the workspace once you have output that word.
A workspace buffer that is up to 4 times the size of list.
http://humanresources.about.com/od/interviewing/a/interview_odd.htm
