Small Brushless Motor Controller
                    I have been working with small brushless motors, but I have been frustrated by the RC type ESC's. Although these RC type ESC's are cheap, efficient and reliable I find the documentation dreadful and the programming a nightmare. Forward/reverse RC type ESC's are also relatively scarce.
I have found this low power 3 phase inverter controller quite stable, robust and easy to use;
http://www.ebay.com.au/itm/like/331257392856?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=107&chn=ps
It has simple direction and speed control. Clearly it is more expensive than RC type ESC's and is rather too large and heavy for a flight ESC but I find it easier to use for stationery applications involving small brushed motors.
In case you're not aware, the Propeller can be used to reprogram many ESCs (the same sort of programming done with a programming card). Just change the constants in the code posted in post #114 of this thread.
http://forums.parallax.com/showthread.php/154854-Open-Propeller-Project-4-Program-our-ESCs-with-a-Propeller?p=1283727&viewfull=1#post1283727
The Propeller will program the ESC with the values of the constants.
For a serial interface with the ESC you could use the program attached to post #113.
I've been tempted to connect a couple ESC lines to a DPDT relay to make it reversible. Swapping two of the three lines from the ESC should reverse a brushless motor.
Phil noted above that standard ESC's can be reprogrammed to be bidirectional. The hacks to achieve this are open source and quite common, but very technical.
I have been experimenting with a common EMax BLHeli ESC and the EMax Program card. I have found that the ESC can be programmed quite easily to be bidirectional, and it works very smoothly and robustly.
This is great news and it means that small bi-directional brushless motors can easily be used for land wheeled robots and water robot thrusters!
Very cool!
Thanks for the information.
