please help debug a simple piece of code (one pin following another)
I know it must be my error somewhere. Please help me to find the problem.
The idea is to have PIN_13 following PIN_14 going high and low. PIN_14 is toggling all right. But PIN_13 is stuck at low.
So without knowing what goes wrong, I trial and error again with this code:
Now when TOGGLE_PIN is low, FOLLOW_PIN stays low. But when TOGGLE_PIN is high, FOLLOW_PIN jumps up and down many times. Why is that?
CON
_clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 5_000_000
TOGGLE_PIN = 14
FOLLOW_PIN = 13
PUB Main
outa[TOGGLE_PIN] := 0
dira[TOGGLE_PIN] := 1
cognew(@entry, 0)
repeat
outa[TOGGLE_PIN]:=!outa[TOGGLE_PIN]
DAT
org
entry
mov outa, #0
or dira, output_pin
zero test ina, input_pin wz 'wait to go high
if_z jmp #zero
or outa, output_pin
one test ina, input_pin wc 'wait to go low
if_c jmp #one
andn outa, output_pin
jmp #zero
output_pin long %1<<FOLLOW_PIN
input_pin long %1<<TOGGLE_PIN
CON
TOGGLE_PIN = 14
FOLLOW_PIN = 13
PUB Main
cognew(@entry, 0)
repeat
DAT
org
entry
mov outa, #0
or dira, output_pin
if_z jmp #zero
or outa, output_pin
if_c jmp #one
jmp #zero
if_z waitpeq input_pin, input_pin 'wait to go high
or outa, output_pin
if_c waitpne input_pin, input_pin
jmp #zero
Try changing all the "TEST ina, xxx" to "TEST xxx,ina" so ina is the second parameter.
This is because ina is a read-only register.
Bean
to
thanks a lot for the help. Is this mentioned anywhere in the manual?
I read the propeller manual about "TEST", which states "TEST is similar to AND except it doesn’t write a result to Value1; it performs a bitwise AND of the values in Value1 and Value2 and optionally stores the zero-result and parity of the result in the Z and C flags"
