World's First (?) Digital Computer in 1939, the ABC
Jameco has an interesting nugget of computing history in their newsletter. A controversy or better yet, conspiracy about the 1939 Atanasoff-Berry Computer
http://www.jameco.com/Jameco/workshop/rollcall/first-digital-computer.html
The ABC weighed over seven hundred pounds and could solve up to 29 simultaneous linear equations. It had no central processing unit (CPU), but used 280 dual-triode vacuum tubes for digital computation. Its memory contained 1600 capacitors organized into 32 bands that rotated on a common shaft once per second within a pair of drums. This allowed the ABC to have a computation speed of 30 actions per second. Data was represented as 50-bit binary numbers. Some of its design concepts are still used in computing devices today.
That "...evening of scotch and 100 mph car rides,..." thing never did work for me
Loadable programming would be a minimum spec of defining a computer.
http://dangerousminds.net/comments/leonardo_da_vincis_incredible_mechanical_lion
There are other examples where lengths of rope and knots (ROM) were used for a programmable device.
http://en.wikipedia.org/wiki/Konrad_Zuse
