28506 GPS questions
MSDTech
1. Is there a way to shorten the cable on the antenna? I will be using this on a small robot (15" footprint) and don't need the long cable. If not, is there a good antenna with a short cable that will work with this unit.
2. I noticed the schematic in the Parallax documents does not match the schematic on the Simplytronics website do not match. Which is correct for the module?
As for the schematic, since SimplyTronics designed this module I would say they would have the latest schematic, however I will check with them.
Up
The curved part should be pointing up. Flat part parallel to the ground.
I just wondered how the shortened cable worked out for you, going to do the same to mine, wanted to make sure it don't effect reception. Also, sounds like you went with opening the weather resistant patch antenna enclosure, I was hoping to re-use the conector end, or just cut and splice the extra cable out.
The cable length must be an active part of the antenna, no acquisition indoor or out, another experiment in futility.
