C: stdio rename function problem?????
As you can see below, I seem to be having a problem, with the rename function.
As a side note, I seem to have created an undeletable directory. Any suggestions besides reformatting.
#include <stdio.h> int main(void) { char *testz; char *testp; testz = "/test/z"; testp = "/test/p"; rename(testz, testp); return 0; }
Project Directory: C:/Documents and Settings/Bruce/Desktop/Rename/ SimpleIDE Version 1.0.2 C:/Documents and Settings/Bruce/My Documents/SimpleIDE/Learn/Simple Libraries/ C:/Documents and Settings/Bruce/My Documents/SimpleIDE/ Updated on: 2015-02-14 propeller-elf-gcc.exe -v GCC 4.6.1 (propellergcc_v1_0_0_2408) propeller-elf-gcc.exe -I . -L . -o cmm/Rename.elf -Os -mcmm -Wall -m32bit-doubles -fno-exceptions -std=c99 Rename.c C:\DOCUME~1\Bruce\LOCALS~1\Temp\ccM8hivF.o: In function `_main': (.text+0x9): undefined reference to `_rename' collect2: ld returned 1 exit status Done. Build Failed! Check source for bad function call or global variable name `_rename'
Thanks for the explanation. Not that it is any big deal, but perhaps stdio.h should be updated to either remove or comment out the declaration, until a function is written.
I thought perhaps one or two, but if there are a lot of them, that makes good sense.
