2600ma Power Stick 88% off at Staples
Publison
Nice little accessory for very little price. Could power a QuickStart or Project Board:
http://www.staples.com/Acesori-Powerstick-2600mAh-Portable-Power-Bank-Assorted-Colors/product_SS3891349?cmArea=home_box1
$6.99. Not sure they are available in store or Internet shopping only.
Between Jim & CuriousOne posting these smoking deals, it's gettin' hard for old erco to keep up!
You may see some of them next year at NYTF. One for sure.
The problem I have with this idea is that the recharging packs I've used turn themselves off if the current being drawn from them drops below a specific level. I have not tested this particular unit from Staples, so it could be different. If it is, please let me know and I'll pick one up!
Meanwhile, with the power packs I already have, the QS board does not draw sufficient current to meet this stay-on threshold. I could always add a resistor straight across the power pack's 5V output, but that wastes a significant percentage of the stored charge.
So I had an idea I'd like to test: Instead of imposing a constant stay-alive current with a resistor, I want to see if a low-duty-cycle load would keep the pack on. (Something like a 20 mA load of 50 ms duration every 5 seconds, probably accomplished with a CMOS 555.)
Has anyone already tried this?
No, but I know what you mean. It reminds me of when aftermarket LED lighting went into cars and the cars would report bulbs out when they weren't. It's a system designed for one thing doing another. USB spec might not be flexible enough to be certified at low current. I have a 1S lipo charger that is USB and I've been through a lot of these USB chargers and the best one was a Tenergy 2200mah I bought at Fry's. It would stick with the charger all the way down to the peak of a 1S lipo charge. You would need to reboot it before the charger would work again after that, but as long as there was some draw it stays on.
But leave the USB charge circuitry in place.
I'm willing to bet you are better at taking things apart and putting them back together than I am, erco. I always break a few things upon disassembly, but it's the putting back together that really screws things up.
Since an external solution is the only solution that fits my limited skill set, I undertook a few minutes ago to find out what it would take to keep my Tenergy pack alive - the one that Curious One brought to our attention in January. (I selected it because it has the highest capacity of the packs I have, and is the one I'd most like to use if I could.) I'd previously determined (on 1/21/15) that a 50 Ohm load was enough to keep the unit on, but that an 85 Ohm load wasn't.
So, starting from that point I used a QS board and an MPS2222 to turn a 50 Ohm load on and off. Long story short, what I determined is that a 100ms on-time every 4 seconds is enough to keep the unit on indefinitely. So the wasted current (to keep it on) has now been reduced 40x, to effectively 2.5 mA.
Now I can design a timer circuit to mimic this action...
http://www.amazon.com/dp/B00UCP6HKK/ref=nosim/?tag=fatwalletcom&linkCode=as1&ascsubtag=ebs2d-1d1d1431016903765sbe&sourceName=forums&sourceId=1441192
Same capacity as the Tenergy but 4x more expensive.
OTOH, the Tenergy won't jump-start your motorcycle.
http://www.ebay.com/itm/Tenergy-6600mAh-6-6AH-Power-Bank-w-Micro-USB-for-iPad-iPhone-Mo-bile-/390449318860?pt=LH_DefaultDomain_0&hash=item5ae897cbcc
6600mAh for $9.99 + FS
Do not tempt erco!
Weak, hoarder erco...
Since there are two output ports, one rated at 1A and the other at 2A, I realized that I probably wouldn't have to make a custom cable to accommodate the keep-alive timer. Instead I simply put the intermittent load (in the form of a small dongle) on the 1A port and use the 2A port to power whatever it is I want to power. I tested this notion and it works great.
Curiously enough, it doesn't work the other way. If I put the intermittent load (re: post #8) on the 2A port, it doesn't keep the power pack alive. Presumably it requires a bigger dummy load. But why bother with that??
Finally, I found that the 100mA keep-alive load can be applied as infrequently as every 7 seconds and still keep the power pack from turning off. This represents an effective current load of just 1.4 mA, a drop in the bucket for a 6600 mAh power pack.
