Ubuntu Linux — Parallax Forums
Ubuntu Linux
Sposht42weSposht42we Posts: 6
edited 2015-04-30 17:11 in Propeller 1
I am trying to download the SimpleIDE program onto my computer however it uses an Ubuntu Linux operating system. To properly download the program, a 'sudo apt-get' program is required to use in the terminal. Does parallax have one or is there one available for SimpleIDE?
  • ElectrodudeElectrodude Posts: 1,683
    edited 2015-04-30 14:27
    Ubuntu comes with both sudo and apt-get - they are both integral parts of Ubuntu. Does the command give you an error message when you run it? If so, what is it?
    sudo runs a program (in this case, apt-get) as a different user (the superuser by default). apt-get installs a package (simpleide, in this case).
  • SRLMSRLM Posts: 5,045
    edited 2015-04-30 14:34
    SimpleIDE works on pretty much any operating system. What are you using?
    You can download the different versions from http://learn.parallax.com/node/640
    edited 2015-04-30 14:52
    You cannot install SimpleIDE with apt-get as it does not exist in any repository where apt could download it from.
    Download the latest version from here: http://learn.parallax.com/propeller-c-set-simpleide/linux and install it with dpkg:
    sudo dpkg -i simple-ide_1-0-1-rc1_amd64.deb
  • evanhevanh Posts: 16,957
    edited 2015-04-30 15:38
    Or double-click on the saved deb file. That should auto-detect it's a package and start the install process for you.
  • xanaduxanadu Posts: 3,347
    It would be cool to see SimpleIDE in apt.
