How could I get a 3.58 MHz frequency from an internal counter?
cbmeeks
I'm reading the documentation on counters but it seems a little scarce on how to actually do certain things. Maybe I'm just missing it.
Anyway, I'd like to generate a frequency that I can control (for a Z80 CPU) that is 3.58 MHz using either the CTRA or CTRB.
I say 3.58 MHz but it would be awesome to get it more granular than that and match the NTSC colorburst frequency of 3.57954.
Could someone point me to a tutorial that explains how to get such a specific frequency? I'd need to output that frequency on a pin, BTW.
Thanks!
Thanks!
https://www.parallax.com/sites/default/files/downloads/AN001-P8X32ACounters-v2.0.pdf
That one explains all the counter mode detail.
Here's a page that shows how to compute and output a given frequency:
http://wardyprojects.blogspot.com/2015/02/propeller-high-frequency-output-using.html
You REALLY need to write a book. :-)
Thanks!
How would that affect video generation on other cogs?
Each counter does what it does independently. Same for the cogs.
If you run off a crystal, a clean multiple of it will have low jitter. Not many ones in play.
Video generation just needs to be adjusted for the non standard clockspeed.
For most drivers, this is easy, and many are written to work off any clock fast enough. If you want, mooch that part and drop it in your driver.
We will have to see what is possible at that speed. Video is for sure. But it might take more cogs to get what you want done.
Good news is TV is the slowest signal, so there is the most time and more is possible at lower clocks.
So, if I used one of those and a PLL8x that's over 114 MHz. PLL4x is still 57.27272 MHz.
What other frequencies and PLL values could we use to get close to the 80 MHz?
I have some. If you like, PM me your address and I'll mail you one.
What I meant by the 14.31818 was that it was the next level up from my 3.579 (of course, you couldn't have known that) that was a multiple of NTSC (I have plenty of 8 MHz too).
But, after reading a bit, I see that 14.31818 is way out of spec for an external crystal. The ideal crystal would be a 7.15908 MHz. It *seems* that the 114.54528 MHz (PLL16x) might be possible and reliable?? That's assuming such a crystal exists.
If so, then the NTSC colorbust clock for the Z80 would have an even split.
Also, I was thinking of using the prop to control the clock of the Z80 which is why I'm not using a real crystal. But, maybe I could still do that and use an external one too?
Oh, and thank you for offering to send me some crystals.
** EDIT **
Hmm, it appears that pushing the prop beyond 100 MHz is simply not a good idea. Especially if all I want to do is control a Z80. So, it would probably be better if I found another way. I just don't know enough about the Z80 to know how to do that yet. I was thinking if the prop could freeze the clock, then I can do certain things like convert SPI RAM, etc.
Also, what I might do is just run the Z80 at the NTSC clock and see how bad the jitter is. This is for a homebrew ColecoVision. So I don't know how accurate the clock needs to be for games to work (and work reliably).
Perhaps the ColecoVision game can live with a little jitter. :-)
To get colour decoded, then frequency and phase are very important, and XTAL will be needed.
To get just a raster and old TV can sync to, in B&W. that's a little more tolerant.
You could try a divide by 4 from 14,xx for 3.57 and /3 for a 4.772726667MHz prop CLK
(not sure if the prop tolerates 33:66 clock ratio, but I'd guess an edge PLL would be ok .
I found an interesting link here
https://www.eecis.udel.edu/~mills/database/memos/TV.TXT
Claims Transmit stability of
["The frequency tolerance of the color burst is specified as 10 Hz or about 2.8 PPM."]
- but I think the TV PLLs can pull their crystals by some tens of ppm so you probably do not need to chase single-digit ppm, but you should check and trim any crystal.
Here is my code:
CON _clkmode = xtal1 + pll16x '80Mhz cpu speed _xinfreq = 5_000_000 PUB main coginit(0, @ASM_ENTRY_POINT, 0) '---------------------------------------------- DAT org 0 ASM_ENTRY_POINT or dira, HF_PIN 'set pin as output mov FRQA, FREQ 'set up the desired frequency mov PHSA, #0 'set the phase back to 0 (optional) mov CTRA, CTRA_MODE 'begin output of the HF signal waitpeq $, #0 'sleep forever '---------------------------------------------- HF_PIN long |< 23 'output on pin P23 FREQ long 12010943 '3.57954 MHz (NTSC) ' CTRMD PLD BPIN APIN | CTRA_MODE long %0_00010_111_00000000_000000_000_001111 FITBut I get nothing. I am using the C3. When I run the following C code using the same pin, it works:
#include "simpletools.h" int main() { square_wave(23, 0, 3579540); while(1) { } }Any idea why the ASM code give me nothing on the scope?
A more prop-zoned crystal value is 3.579 x 1.5 = 5.3693 MHz, & google finds a mention of running games/Z80's at that.
It also finds that Digikey has stocks of the related 21.47727MHZ, (from 2 vendors even)
A HC6323 would divide that by 4 for the Prop 5.3693 MHz, and then the PLL/24 gives Burst.and could also give Colour phase modulation to 24 steps in 360'
Prop cannot divide by exactly 24 in HW without some SW help - it divides by 24+25/3e8
You need to set pin23 in the CTRA_MODE as APIN (now it's pin15): But it makes not much sense to do this in Assembler and waste a full cog just to setup a counter. The same in C (untested):
Andy
BTW: The Prop video generator shows colors fine (in NTSC mode) with a 80MHz clockfreq, so the jitter can not be a big probem.
The Prop's frqx registers don't act like dividers, but multipliers. So I think a crystal around 2/3 * N * NTSC, rather than one of 3/2 * N * NTSC would work better.
I visualize the Counters as adders, which is how they actually work.
Using my numbers, I get (NTSC*3/2)*16/24 = 3579545, and the adder-effect SW correction is needed less than once per frame.
However NSTC *2/3 is too low for the PLL Lock range, but 2 * NSTC *2/3 is ok, but when that is PLL'd x16 it gives
21.333333 * NTSC, removing the option of phase-steps for Colour.
This shifts the problem from low-frequency correction, to high frequency jitter, and it will generate jitter out by giving 21.21.22.21.21.22... Clocks - it may be that the PLL mode in counter block can filter that jitter well enough, but I would expect to still see some phase modulation at the 1.193MHz jitter rate. Maybe the OP can tolerate that ?
I've certainly got some studying to do. Mainly just learning how the Z80 works and how the propeller work. Daunting sometimes.
I'm more familiar with 6502 and Arduino.
VAR long frq_val, ctr_val PUB setup_clock( Hz, pin ) : something | sc ' PLL is preferable to NCO for jitter, but only goes from 500 kHz to 128 MHz if Hz < 500_000 ' NCO mode (easier, but possibly more jitter) ctr_val := constant( %00100 << 26 ) | pin else ' PLL mode, harder to set up but reduces jitter sc := %011 ' maps to /16, exactly offsetting the PLL's *16 repeat while (Hz < 4_000_000) and (sc > 0) Hz <<= 1 --sc repeat while (Hz > 8_000_000) and (sc < 7) Hz >>= 1 ++sc ' set it up the counter, and match the integer period ctr_val := constant( %00010 << 26 ) | (sc << 23) | pin ' either way, now set up the frequency control frq_val := frac32( Hz, clkfreq ) PUB frac32( num, den ) repeat 32 num += num result += result if num => den result |= 1 num -= denJonathan
