Sample stream mixer
Hello.
I tried to go as far as I could in a reasonable amount of time, and now I am submitting myself to you for judgement.
I am trying to write my own simple mixer, but got stuck when trying to use the sample stream from Chip's vocaltract.
I looked through stereospatializer and copied bits for the timing, but it is still not going right.
I think it isn't synced and is reading from the hub as the hub is being written to. There is bad digital noise, even when it is supposed to be silent.
If that is the case, how do I sync the mixer and vocaltract?
Thanks for any help you can provide.
VAR long samples, cnt_ PUB start (addy) samples := addy cnt_ := clkfreq / 20_000 cognew(@mixer, @samples) DAT org 0 mixer mov temp1, par rdlong temp1, temp1 mov temp2, #6 shl temp2, #26 add temp2, #15 mov ctra, temp2 mov dira, #1 shl dira, #15 mov t1, par add t1, #4 rdlong cnt_ticks,t1 'get cnt ticks mov cnt_value,cnt 'prepare for initial waitcnt add cnt_value,cnt_ticks :loop waitcnt cnt_value,cnt_ticks rdlong frqa, temp1 jmp #:loop temp1 res temp2 res t1 res cnt_ticks res cnt_value res
