Remote connection to Memsic 2125
Hello,
I've attached a Memsic 2125 to a programmable microcontroller. And, I'm able to obtain the expected data when the accelerometer is attached via 6 inches of wire. But for this particular project, the sensor needs to reside 3 feet from the microcontroller.
I soldered connectors to 3 feet of CAT 5 cable and reconnected the Memsic. But, with the 3-foot run of cable, the readings suddenly slow down. (Periodically, they'll speed up to my original setting of 4 readings per second; but, for the most part the readings are extremely slow (> 1 second per reading).)
If the readings were consistently slow, I'd assume that the cable run had introduced problematic resistance. But, because the readings are periodically normal, I'm baffled/puzzled by the behavior.
I wondered if anyone on the forum had suggestions as to how I might trouble-shoot and resolve the issue?
Thanks!
Thanks!
1- Connect power and ground to the Memsic using one twisted pair of the cat5.
2- Connect each signal using a twisted pair, with the ground connected only at the Memsic or Microcontroller end, not both ends.
3- Make sure all the connections are good.
4- Check the power supply for the correct voltage and no ripple or other noise.
Use a scope to check power and signals if you have one available.
