Elev-8 v2 vibration
I am having a vibration issue with from what I can see is 3 out of the 4 props on my elev-8. If I look at the threaded part that screws to the motor at the top is a tiny nub from machining that doesn't seem to run true. I cleaned up the service of the motor and also re machined the surface of the aluminum part that touches the motor with out any improvement. I am looking into balancing the props but I'm sure if the threaded part that holds it isn't true the balance will not help. I also have a noise in one or all motors under half throttle.
Welcome to the forums! We'll get your ELEV-8 V2 into the air without too much work. This product must be built precisely according to instructions in order to fly.
It sounds like the propeller adapter on the top of your motors is out of true - is that right? It would be the first time I've seen this, but it's certainly possible. I have a couple of things you need to check and verify:
- Spacer rings for propellers. The propellers will not center on the motor's propeller adapter unless you use the correct black plastic spacer ring. Can you verify that you installed the ring?
- Motor mount screws to standoffs. If one screw is missing on the motor mount then you'll experience vibration. They need to be firmly installed with the lock washers. Are they fully assembled?
- Propeller balancing. I've never done it and haven't experienced any visible problems from not balancing propellers.
- Motor screws to motor mount. Is each motor attached with the 3mm x 6mm screws?
I have to ask these questions because I've seen these built a variety of ways, often not according to instructions. Cold solder joints in the motor wires are usually the biggest problem.
We can knock these issues out one at a time and get you in the air.
Thank you for your quick reply and help. Here is a picture of my build that I hope will answer some or all of your questions. I completely understand your "from the ground up" questions about my build and should have asked the same things. If I have time tonight I will ohm out all of the connection wires.
Now that it's right, is the vibration reduced?
You really should not have to go through all this. They should work out of the box. The components Parallax supplies are of good quality.
Could you tether the Quad to a good surface ans run it up in a static mode? If you have a vibration, you should be able to see on of the booms oscillating.
If you could post the video, that would be great also.
This is a YouTube video of the clicking sound I am hearing
BTW, don't run the motors too long without the props. They need the props for cooling.
Here is a YouTube video of most likely what my clicking sound is. I'm going to pull apart my motors and check it out this week.
Interesting video. Looks like a QC issue. I'm sure Ken would like to know about this. My four motors seem fine, but they may have been from a different lot.
Not to worry, Parallax will make it good, they always do, they are the best in customer satisfaction.
Welcome to the Forums!
I bought this product because of the ability to add on to it and use it as a platform to learn more about this technology. Half of the fun of electronics and such is tuning and tinkering for me.
I'm not going to place a name here but at the same time as I purchased the elev-8 I bought a ready to fly quad copter with other features totaling 1700 dollars including some extra props.
I will have some time tomorrow to experiment with what is going on with my elev-8 and greatly appreciate the help guys.
I just want to make a quick comment about my background.
I am 28 years old. I took three years of vocational machine shop with much focus on automated machining. I am currently in the automotive industry as a sevice equipment technician. I install and repair car tire balancers computer controlled tire changers and computer operated optical wheel alignment machines that use camera technology to take pictures of reflective targets that get mounted on your cars wheel to calculate the alignment angles in reference to the manufacture spec.
My dream job would be to develop and test electro-mechanical machine that other people can use to solv a problem they face.
We don't test the motors and ESCs, so it's possible they could have problems. I'm happy to replace everything you need.
kgracey@parallax.com.
Sorry for the troubles!
I just started to pull apart my copter and found one motor has a winding sticking up like the one video I posted and I fixed it the same way the guy depicted.
One other observation is on the clip side of 2 out of the four motors were two metal washers then one plastic one followed by the clip. On the other two mothers were four plastic washers.
I put a meter to the motor and got .1 to .2 ohms between the three wires. The connecting wires also came in low at from .2 to .3 ohm.
These motors are from China and we recently received a box of them which experienced some sort of excessive force during shipment, like they crossed the ocean in a john boat with a 10 hp motor. We sorted through them and discarded damaged motors, but it's possible a few made it out in our kits.
Our Purchasing Manager has contacted the supplier (KEDA Model) and filed a QA/QC request. They've replied by telling us they can do a "dynamic balance" for the motors. I'm not sure what this means but we'll find out, visiting them as necessary to get this straight.
If any customers have ELEV-8 problems please do not hesitate to post them here or contact us. We'll replace any parts you need. When our new Flight Controller comes out it'll be easier to diagnose some of these problems.
And Mysticmindset, thank you for the suggestion that I be promoted. I don't want any more responsibility at Parallax.
https://youtu.be/K1QpkzGxr6E
http://youtu.be/pDwpgP8P1j8
Not sure what you mean by "same amount of threats showing". When using the isolation mounts, (blue), on the controller board, you should gently snug the nylock nut down ensuring there is still enough play for the board to "float".
https://youtu.be/DknL1HpIGZs
What happens with the new motors if you run them up on the ground?
Some design changes would enable a vibration-free full throttle, too.
