VGA "Not Supported Mode" on a Samsung TV — Parallax Forums
GenetixGenetix Posts: 1,774
edited 2015-05-26 17:01 in Propeller 1
I used my Demo Board on my Samsung TV and only the VGA Text Demo worked.
All the other VGA demos gave me a Not Supported Mode message.
The manual for my TV lists the supported resolutions along with the Horizontal (H), Vertical (V) , and Pixel Clock (P) Frequencies.
I know that Pixel Clock is commonly talked about but how are the Horizontal and Vertical frequencies related.
For example, these are IBM supported:
640x480 H: 31.469 kHz V: 59.940 Hz P: 25.175 MHz
720x400 H: 31.469 kHz V: 70.087 Hz P: 28.322 MHz
I know that I should probably be using a real VGA monitor but information like this may help others get their displays to work or help the coders make other resolutions possible.
The rest of the table is for VEAS (whatever that is) and I will double check that I have the correct manual for my TV.
  • davidsaundersdavidsaunders Posts: 1,559
    edited 2015-04-23 12:43
    Genetix wrote: »
    If you mean VESA, that is a series of video standards, some of which apply to the resolution adn frequencies.
    I do not have the link to the VESA stuff at the moment.
    What resolution were you having trouble with?
  • RaymanRayman Posts: 15,934
    edited 2015-04-23 19:45
    I've noticed that 640x480@60Hz is almost universally supported. 720p @60Hz is also almost universally supported.
    Anything else in small monitors is hit or miss. New, big monitors seem to universally support 1080p @ 60 Hz.
    edited 2015-04-24 00:23
    Genetix wrote: »
    Can you be a bit more specific?
  • GenetixGenetix Posts: 1,774
    edited 2015-04-24 11:04
    I hooked up my Demo Board to the PC connection of my TV (VGA Connector) and when I ran the following Demos the TV would show "Not Supported Mode" on the screen.
    Propeller Demo
    VGA Demo
    Microphone to VGA
    VGA 512x384 Demo
    VGA HiRes Text Demo
    VGA Tile Driver Demo 2
    VGA Tile Driver Demo 3
    Only this demo worked properly - VGA Text Demo
    This is from my TV manual under the section PC Display:
    Display Modes
    Both screen position and size will vary depending on the type of PC monitor and its resolution.
    The resolutions in the table are recommended. (All resolutions between the supported limits are supported)
    Mode     Resolution      Horizontal          Vertical          Pixel Clock      Sync Polarity
                             Frequency (kHz)     Frequency (Hz)    Frequency (MHz)  (H/V)
    IBM      640 x 480       31.469              59.940            25.175            - / -
             720 x 400       31.469              70.087            28.322            - / +
    VEAS     640 x 480       37.861              72.809            31.500            - / -
             640 x 480       37.500              75.000            31.500            - / -
             800 x 600       37.879              60.317            40.000            + / +
             800 x 600       48.077              72.188            50.000            + / +
             800 x 600       46.875              75.000            49.500            + / +
             1024 x 768      48.364              60.000            65.000            - / -
             1024 x 768      56.476              70.069            75.000            - / -
             1024 x 768      60.023              75.029            78.750            + / +
             1280 x 720      45.000              60.000            74.250            + / +
    -> The interlace mode is not supported.
    -> The set might operate abnormally if a non-standard video format is selected.
    -> DVI does not support PC function.
    -> Separate and Composite modes are supported. SOG is not supported.
    edited 2015-04-24 11:21
    Well, having owned four different VGA flat screen monitors of various brands, I have pretty much concluded that the automated identification of a video signal can vary greatly from brand-to-brand.
    I have not had an experience with VGA in a Samsung TV, but the past two decades of flat screen video development have been very fast paces and there has been a lot of litigation over intellectual property. The end result is that even if the Propeller is supposed to work, the monitor or TV port just may refuse it in some modes for reasons unknown. I have similar issues when attempting higher resolution formats in Linux.
    I have also had similar issues with HDMI. And I have one supposedly HDMI capabale monitor that will only accept VGA.
    Generally, I have concluded that if you try to save money by buying ON Sale and off-branded monitors, you get more problems. View-Sonic seems to have been particuarly disappointing to me.
    You could make a Puppy Linux LiveCD and boot that in your regular computer. Then you could run through a comparison of how the Samsung VGA works with alternative VGA clocking in Linux. The Propeller is programable, so it should be able to conform to anything if the right timing is provided at the right impedances and voltage levels.
    And you might check your VGA cable for length and quality. An up-grade in cable might just make all the trouble go away.
    edited 2015-04-24 11:41
    Perhaps but Samsung is certainly not an "off-branded" monitor. I think it's basically considered the top of the line these days. Probably the only real solution is to stick with standard 480p or 720p.
    edited 2015-04-25 15:18
    Many of the Parallax Propeller demos use non-standard vga timings. I think that is why you are having trouble...
    PC monitors will work with almost any timing these days. But, TVs seem to be more picky.
    How old is this TV? I've also noticed that older monitors and TVs are more picky than new ones...
    edited 2015-04-29 12:05
    Loopy, I've always found Viewsonic to be a very reputable brand though my last CRT was a Sony (someone sold it to me for $50).
    Rayman, my TV (LN-S2338W) was built September 2006 in TJ, Mexico. It was given to me so I can't complain. :P I've used it as a PC monitor and only had it not work once.
    edited 2015-04-29 21:47
    Genetix wrote: »
    I have to admit that my views are from Taiwan, not the USA marketplace.
    A. Samsung is not popular in Taiwan due to S. Korea being a major competitor, but S. Korea certainly supplies the USA market.
    B. My bad experiences with Samsung and Viewsonic may be due to Asian electronics producers selling off their less successful products in Taiwan... stuff that may never have reached the USA market.
    C. Sony? They produce nice stuff, but in Taiwan it is generally over priced.
    edited 2015-04-30 05:41
    I have failrly recent Sylvana 32 in LCD TV. The PC input (VGA) would only work in the lower res modes, and the HDMI could not be detected by my Raspberry Pi. When it finally was detected, the TV and the device reported different resolutions. For example, the RPi 2 thinks it 1360x768 but the TV says is 1154xsomething.
    Like Rayman said, monitors work with anything, TV's are still very picky. But I still threw out all my tube monitors anyway, they are just too bulky and use too much juice.
    Maybe the thing to do is change the timing in the code for the other demos?
    edited 2015-04-30 07:14
    Yes indeed, but it seems we need a tutorial for new users to explore this with whatever they might have. Everyone has a different situation, so it is hard to sort out what exactly might work without trial and error with the actual unit.
    The one other thing I do wonder about is how well the resistor network on the Propeller for VGA targets the ideal impedance. A few years back there was a thread that discussed the the values of the resistors could be altered to get a better fit. So TVs and VGA may just ignore the Propeller in higher resolutions due to the impedance matching being marginal. It is easy enough to correct, and the colors are better as well.
    I picked up a VGA LCD monitor at Goodwill and only the VGA_Demo acted goofy in that the screen wasn't initially centered; I noticed that demo uses 640x400@70 Hz.
    The other demos all look great but I did notice the VGA_Tile_Driver_Demo2 which should be 60 Hz actually was 56 Hz.
    I initially thought the VGA_512x384_Bitmap_Demo didn't work because of all the horizontal line segments but after seeing Microphone_to_VGA which uses the same driver works fine and looking at the code those lines are supposed to be there.
    I still need to try the Application Notes GUI code but I love the Propeller's VGA capability.
