Coding for GSM module
Hi,
I want to trigger the GSM module to send message to recipient when the signal exceed the threshold. Anyone can advise the C coding?
I suppose UART can be used but I could not find relevant coding on the net.
Parallax does not carry a GSM device. Which one are you referinng to? Which Parallax processor are you interfacing to, Basic Stamp or Propeller?
Propeller project board. I have a GSM2 click board, when triggered, will send a message out.
http://forums.parallax.com/showthread.php/149716-SIM-900-GSM-module-interface-object-WIP
Being a terrible coder the object is buggy and faulty by definition, but might get you started.
Massimo
Is the code available for use?
