Memory Interface and IO Peripherals in 2015 - Page 2 — Parallax Forums
2»
  • markmark Posts: 253
    edited 2015-04-20 22:51
    >Got any links?
    I don't, and I really haven't been paying too much attention to MCU product lines as of late. I thought chips with LCD drivers and memory interfaces were pretty common now.
    From what I can tell, there's budget application processors sporting Cortex A5s (telechips, mediatek) priced right around the $5 mark.
  • RaymanRayman Posts: 16,010
    edited 2015-04-27 19:12
    That new FTDI chip looks very cool, thanks jmg...
    I'm thinking I could easily turn that into VGA or HDMI output onto a PC monitor...
    Still, P2, if it comes, could do that with component output and no external ICs, which would be very nice...
  • jmgjmg Posts: 15,200
    edited 2015-04-27 19:32
    Rayman wrote: »
    Yes, P2 would still compete.
    I'm not sure how the FTDI part would manage VGA/HDMI ? - as it seems display-list based and so may not give a time-linear raster that VGA needs. (It may be active-LCD only.)
    Let us know what you find.
  • bruceebrucee Posts: 239
    edited 2015-04-28 09:59
    512K holds 800x600x8bit, which is fairly low resolution these days, so the P2 still needs external memory to do high resolutions, and will it have HDMI differential transmitters with 8b/10b encoding???
    Memory has always been the weak point of the Prop design, and at 180 nm that will continue with the P2. So I'm not sure how I see that it is competitive in the general marketplace, the DIY community could be a different story, but that is a small market and now quite fragmented.
