Simple question with OBC's HC-06 Bluetooth LED Demo
I've been working with one of those inexpensive HC-06 Bluetooth modules from eBay and I've been following an excellent "how to" that OBC wrote a few years ago here: http://www.gadgetgangster.com/news/56-jeffs-shop/534-bluetooth-howto.html
Everything is connected and I'm able to run the "Snake" and "LED" demo programs, but there seams to be a problem with the program receiving the majority of commands. I have to type the key command several times (~20- ~100) before the program responds and the LED turns on or off. The examples show the command only having to be typed in once for the program to respond.
Any suggestions on what I'm missing? Is there a way for the program to wait until "a:=serial.rxcheck" receives a value?
Thanks for your time,
Dave
Dave
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
bt_rxd = 20
bt_txd = 21
led = 19 'led placed between 18/19 - Insert negative leg into p18
OBJ
serial : "FullDuplexSerial"
PUB LedOn | a
serial.start(bt_txd,bt_rxd,0000,9600)
dira[led] := 1
dira[led-1] := 1
outa[led-1] := 0
repeat
a:=serial.rxcheck
if a == 97
outa[led] := 1
serial.str(string("LED ON",13))
if a == 98
outa[led] := 0
serial.str(string("LED OFF",13))
I was reading through the instructions a few more times and realized that I had failed to set the Baud Rate in the serial Terminal to match the Bluetooth module, 9600. The mismatch allowed data to come in, but mostly garbled the data going out. Hopefully this helps someone else someday. Again, a huge shout out to OBC for this excellent demo. Thanks!
Dave
