C: Solution Needed
idbruce
This quote is taken from the Learn C tutorials:
This presents a problem for copying data, instead of sharing it, such as with the use of memcpy. It would be nice if we had a gcc compatible volatile_memcpy function for use with the Propeller. And perhaps one that could later be added to SimpleIDE for those that may require such a function. I came across this, but they left out the important part, which is most likely GCC specific:
but from what I have seen, it should probably be more like this:
Source: http://learn.parallax.com/multicore-approaches/cores-sharing-dataThe Functions lesson Memory Functions Can Share showed you how to make functions share information with global variables instead of with parameters. Code running in different cogs can use this technique to exchange information as well. There’s just one extra detail: when you declare global variables for cores to share, you have to precede each one with the keyword volatile. So instead of int globalVar, the declaration would be volatile int globalVar.
size_t volatile_memcpy(volatile void *d, volatile void *s, size_t n)
code here
void * volatile_memcpy(volatile void *d, volatile void *s, size_t n)
code here
Forget memcpy() just use: And define the types of n, s1 and s2 as you like.
Job done.
Simple yet elegant. Awesomely cool!
I once was carefree, ahhh those were the days
I suppose n would be sizeof.....
Would this work? while(sizeof(SOURCE)--) *d++ = *s++;
There now appears to be a contradiction and it now appears to be a string copy. What about copying an entire struct?
During my research of memcpy, I came across two definitions, one from Microsoft and the other from Apple. Both of these definitions had conditions for copy forward or backward, based upon the data types. And both of these definitions were certainly a lot more complicated than a one liner.
1) Copy a string?
2) Copy some other area of memory?
3) Copy a struct?
memcpy is the same no matter where it's defined. For example for OSX
NAME memcpy -- copy memory area LIBRARY Standard C Library (libc, -lc) SYNOPSIS #include <string.h> void * memcpy(void *restrict dst, const void *restrict src, size_t n); DESCRIPTION The memcpy() function copies n bytes from memory area src to memory area dst. If dst and src overlap, behavior is undefined. Applications in which dst and src might overlap should use memmove(3) instead. RETURN VALUES The memcpy() function returns the original value of dst. SEE ALSO bcopy(3), memccpy(3), memmove(3), strcpy(3), wmemcpy(3) STANDARDS The memcpy() function conforms to ISO/IEC 9899:1990 (``ISO C90'').Note the memcpy does not like overlapping memory areas.The point of my post was to enable copying of data from one cog to another in a standard tradition that memcpy can be used without cogs. So in other words, I want to be able to:
1) Copy a string
3) Copy a struct
1) strcpy or strncpy
2) memcpy or memmove
3) Simply assigning structs: a = b; where a and b are the same struct type.
I think you misunderstood that. The volatile keyword is used to prevent the compiler from optimizing the variable/struct away.
This sometimes can happen if your main program just sets values to a variable and a COG program reads them and does it's job depending on the value.
The compiler will see, that the main program just sets values but never uses them and optimizes the variable away which is not good because then the COG program never gets something to do.
A memcpy should never be optimized away...
It it worries you that memcpy may fail then just use the solution in post #2.
You like work arounds. I like to have working functions at my disposal that don't generate warnings.
Let's see, if you want to copy a string, you must do it this way, if you want to copy a struct, you must do it this way, if you want to copy other memory, you must do it this way.
Most compilers define "char" as "int8_t". In other words, it's just an 8-bit, signed variable. It doesn't matter that the name is "char". Because of this exact confusion, I much prefer the use of uint8_t, int8_t, uint16_t, int16_t, uint32_t and int32_t instead of their english counterparts.
It might look like a string copy, but all you're doing is copying byte-by-byte, which is exactly what you want.
Yes, this I know, but I am unfamiliar with how the memcpy for GCC is implemented. Is it always a byte for byte copy?
In my current endeavors, I am working a lot with structs, where either the whole struct will be copied or just parts of it, with varying types of data, and often these structs will be in different cogs.
Probably a good idea.
This forum has it's ups and downs but it's a lot better than most of the Internet. Just remember that.
To fully answer your question, here ya go! https://github.com/totalspectrum/proplib/blob/e54fd9572c80619ef6a85a13f66391cbef7b9c51/string/memcpy.c
To directly and simply answer your question, it does byte-by-byte some of the time. If the variables are both word-aligned, it does word-by-word. Pretty cool actually... I wouldn't have thought of that.
Yea David, but there are some on here that get away with a lot more than others. Preferential treatment.
The first response was "You worry too much"..... Is that a helpful phrase? I think not..... but instead I did my best to let it roll off.....
First word was "YOU".... Did a compliment follow? No, instead it was something derogatory.
Ah I see. I did not notice that "You worry to much" could be taken as condescending, which of course it can be. Certainly not my intention.
Hey, you deleted the "He needs a hangin' " post. I quite enjoyed that little joke.
Any resemblance between my behaviour and intelligence, real or fictional, is purely coincidental.
As for preferential treatment, well I have been warned to keep myself in check on occasion, always with good reason.
As for memcpy, the contract is that n contiguous bytes of memory get moved. It does not matter how that gets done.
We all have our good points and our bad points, and we all have to accept the good with the bad. Many of the folks around here are like family, and that includes you, but like all families, we have our quabbles and quarrels. I do my best to keep in mind that we are all unique with different personalities.
Earlier you wrote:
It has been quite some time since I have been heavily involved in C.... Now if I am not mistaken, it isn't that easy with pointers.... Pointers have to be handled differently, don't they?
I have always seen memcpy for structs and such and I can't ever remember seeing a struct copied that way. Maybe I just wasn't paying close enough attention.
Is there any benefit to a memcpy?
struct my_struct { int x; int y; char a; }; struct my_struct source_struct; struct my_struct dest_struct; void main(void) { dest_struct = source_struct; }Under the hood it should just load three parameters (source address, dest address and length) and call a memory copy routine.
What I was suggesting is that "a" and "b" are the structures themselves not pointers to structures. Like so:
typedef struct { int a; char b; } my_struct_t; my_struct_t source = {1, 2}; my_struct_t dest = {3, 4}; dest = source; // dest is now {1, 2}If "a" and "b" are pointers to structs then "a = b" only copies the pointer not the content of the structmy_struct_t source = {1, 2}; my_struct_t dest = {3, 4}; my_struct_t *sourcePtr = &source; my_struct_t *destPtr = &dest; destPtr = sourcePtr; // dest is unchanged.
