Ws2812 code and terminal not working right.
I making a small light for my robot using the ws2812 leds. I modified the code to change lights and patterns which is selected by the ( int h)
The problem is when I try to run terminal code to change (int H)h the led pattern changes but the light wont flash?
Also is there a simpler way to code this?
ws2812 Simple Test.c
#include "simpletools.h" // Library includes
#include "ws2812.h"
#define LED_PIN 7 // led chain pin and count
#define LED_COUNT 4
ws2812 *leds; // Set up ws2812 instance
int a1[] = { COLOR_RED, COLOR_RED, // light pattern a persuit
COLOR_BLUE, COLOR_BLUE };
int a2[] = { COLOR_BLUE, COLOR_BLUE,
COLOR_RED, COLOR_RED };
int b1[] = { COLOR_YELLOW, COLOR_YELLOW, //light pattern b caution
COLOR_YELLOW, COLOR_YELLOW};
int b2[] = { COLOR_BLACK, COLOR_BLACK,
COLOR_BLACK, COLOR_BLACK };
int c1[] = { COLOR_RED, COLOR_RED, //light patter c stop
COLOR_RED, COLOR_RED};
int c2[] = { COLOR_BLACK, COLOR_BLACK,
int d1[] = { COLOR_WHITE, COLOR_WHITE, //light patter d inspect
COLOR_WHITE, COLOR_WHITE};
int d2[] = { COLOR_WHITE, COLOR_WHITE,
COLOR_WHITE, COLOR_WHITE };
void main()
leds = ws2812b_open(); // Open leds instance
int time; //blink time delay
int color1; //pattern1
int color2; //pattern2
int i = 0;
int h;
while(1)
if (h == 0)
color1 = (a1);
color2 = (a2);
time = (250);
else if (h == 1)
color1 = (b1);
color2 = (b2);
time = (750);
else if (h == 2)
color1 = (c1);
color2 = (c2);
time = (500);
else
color1 = (d1);
color2 = (d2);
time = (750);
i = (i + 1) % 2; //blink count
if(i == 0) // if i is 0
ws2812_set(leds, LED_PIN, // Display pattern A
color1, LED_COUNT);
else // Otherwise...
ws2812_set(leds, LED_PIN, // Display pattern B
color2, LED_COUNT);
pause(time); // blink time delay
