propgcc now in the Parallax github - Page 6 — Parallax Forums
13468911
    edited 2015-04-02 16:00
    Getting closer. Looks like openspin is the last remaining piece :)
    I submitted the openspin changes but they haven't been merged yet. I'm also not completely happy with the way the spin2cpp, spinsim, and openspin Makefiles work. They store their build artifacts in the source tree and don't provide a way to override that on the make command line. I sent email to Eric to see if we can make that a bit more flexible so that the artifacts can be put in the same xxx-build tree that is used by the other components like gcc, binutils, etc.
    edited 2015-04-02 17:08
    Ugh. I have changes in pretty much all of the Makefiles to push. I can push the ones for propeller-gcc and spinsim but I need to get approval for spin2cpp and openspin. The propeller-gcc build might be suboptimal until I get that done.
  • DavidZemonDavidZemon Posts: 2,973
    edited 2015-04-02 17:26
    We'll survive.
    I tried using gcc 5 for the first time tonight. It didn't go well. PropWare makes use of cstdint and other C++-style includes which aren't available :(
    edited 2015-04-02 17:32
    We'll survive.
    Yeah, I think it's a work in progress at the present. If you switch back to gcc4, let me know if you have any trouble with binutils or the library. Those are new even though the compiler itself is still the version from the propgcc repository.
    edited 2015-04-02 17:43
    Oh! Glad you asked. I just tried gcc4 from this new repo for the first time and it too is missing cstdint and other related C++ stuffs
    edited 2015-04-02 17:51
    Okay, I can probably fix that. Eric skips the build of the standard c++ library because it doesn't work with the new compiler yet. Or, maybe it doesn't work with the new binutils. I guess I'd better check that. In any case, I can add it to the list of targets to build when gcc4 is being used as the compiler.
    edited 2015-04-02 18:02
    David Betz wrote: »
    Well, that doesn't work either. I think I'm going to have to make propeller-gcc use the old binutils and library as well. The problem is, the P2 support has been removed from binutils but it's still in the old compiler so the makefile tries to generate libstdc++ P2 builds and fails. I don't have time to do that tonight. Maybe you should make your gcc4 builds use the propgcc project for now.
  • SRLMSRLM Posts: 5,045
    edited 2015-04-02 19:42
    We'll survive.
    I haven't really been following this conversation, but this did catch my eye. If it turns out to be a permanent problem could you post up a few notes on what needs to change from GCC<now> to GCC5?
    I'm waiting for everything to settle down, then I want to compare binary sizes with the new version.
    edited 2015-04-03 06:36
    I just pushed changes to propeller-gcc to make it build libstdc++ for gcc4 builds.
    edited 2015-04-03 07:06
    Openspin is spinning into a nose dive :(
    [08:57:05][Step 3/6] make[1]: Leaving directory `/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/71b5f7d6548ebb35/openspin'
    [08:57:05][Step 3/6] Installing openspin
    [08:57:05][Step 3/6] cp: cannot stat &#8216;/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc-build/openspin/openspin&#8217;: No such file or directory
    [08:57:05][Step 3/6] make: *** [openspin] Error 1
    [08:57:05][Step 3/6] Process exited with code 2
    And when i log into the server:
    dzweb@davidzemonname:~/TeamCity/buildAgent/work/propeller-gcc-build$ ls
    binutils  gcc  lib  target
    edited 2015-04-03 07:14
    Ugh. This is because Parallax has not yet merged my changes to the OpenSpin Makefile.
    edited 2015-04-03 07:24
    David Betz wrote: »
    I just pushed a change that I hope will fix this until the OpenSpin Makefile is updated.
    edited 2015-04-03 10:16
    Roy merged my changes to the openspin Makefile but then I found a few other things that needed to be changed. I now have push access to OpenSpin so I fixed them myself and also updated the propeller-gcc Makefile accordingly. I think this should fix the build and the gcc4 build should now include libstdc++ as well.
    edited 2015-04-03 12:51
    David Betz wrote: »
    FYI, I did a clean checkout and default build (for gcc4) and it completed successfully.
    edited 2015-04-05 17:16
    Overall it looks like things are going well for TeamCity. I think builds have stabilized for the most part. Windows builds are still failing due to not finding openspin/openspin.exe though.
    edited 2015-04-05 17:27
    Is this a naming problem? Is there an openspin/openspin? Did I mess up the adding of the .exe extension?
    edited 2015-04-05 18:44
    Ah, I lied. Sorry. The problem is that openspin.exe isn't be recognized as a command. It exists and has the correct extension, but the error is "command not found" from the loader module
    [22:46:11][Step 3/5] make[1]: Entering directory `/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/71b5f7d6548ebb35/loader'
    [22:46:11][Step 3/5] TOOLCC: i586-mingw32msvc-gcc
    [22:46:11][Step 3/5] CFLAGS: -DMINGW -Wall -Isrc/common -Isrc/runtime -Isrc/loader
    [22:46:11][Step 3/5] LDFLAGS: -DMINGW -Wall -Isrc/common -Isrc/runtime -Isrc/loader
    [22:46:11][Step 3/5] SPIN:
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/bin/msys/bin2c.exe
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/propeller-load.o
    [22:46:11][Step 3/5] src/loader.c: In function &#8216;WriteFileToSDCard&#8217;:
    [22:46:11][Step 3/5] src/loader.c:1354: warning: format &#8216;%ld&#8217; expects type &#8216;long int&#8217;, but argument 2 has type &#8216;size_t&#8217;
    [22:46:11][Step 3/5] src/loader.c:1361: warning: format &#8216;%ld&#8217; expects type &#8216;long int&#8217;, but argument 2 has type &#8216;size_t&#8217;
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/loader.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/lmm-image.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/xmm-image.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/xmm-image2.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/pex-image.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/loadelf.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/packet.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/PLoadLib.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/p1image.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/config.o
    [22:46:11][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/expr.o
    [22:46:12][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/system.o
    [22:46:12][Step 3/5] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/port.o
    [22:46:12][Step 3/5] make[1]: openspin.exe: Command not found
    [22:46:12][Step 3/5] make[1]: *** [/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/obj/msys/serial_helper.binary] Error 127
    [22:46:12][Step 3/5] make: *** [/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-win32-build/loader/loader-built] Error 2
    [22:46:12][Step 3/5] make[1]: Leaving directory `/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/71b5f7d6548ebb35/loader'
    [22:46:12][Step 3/5] Process exited with code 2
    edited 2015-04-05 18:48
    Okay, I guess this is the problem of trying to use the target executables to build on the host. Also, I found a problem with invoking the sub-makefiles for openspin, spin2cpp, and spinsim. I'm trying out a fix for that now. It looks like I need to setup an environment for generating Windows builds.
    edited 2015-04-05 19:07
    David Betz wrote: »
    Ha! I must be more tired than I thought. I didn't even make the connection, that it shouldn't even be trying to run an exe file :P
    edited 2015-04-05 19:15
    I just pushed my change to correctly (I hope!) invoke the openspin, spin2cpp, and spinsim Makefiles. However, I don't think that will fix the openspin.exe issue. I'm not sure why that is even happening. I'll try to get a cross build Linux environment setup to diagnose this problem but I won't be able to do it today. Sorry for the problems.
    edited 2015-04-08 06:32
    Life is pretty good on the gcc front I think. The commit you pushed yesterday built fine for four of the six the builds. Windows still failing, as you suspected.
    Unfortunately, building PropWare now fails (using gcc4) with the following message:
    [08:30:37][Step 4/8] /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/37ab7af7b05eff17/PropWare/seeedtftfast_as.S:127: Internal error!
    [08:30:37][Step 4/8] Assertion failure in operand at /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/71b5f7d6548ebb35/binutils/gas/expr.c line 1386.
    [08:30:37][Step 4/8] Please report this bug.
    [08:30:37][Step 4/8] make[2]: *** [PropWare/cmm/CMakeFiles/PropWare_cmm.dir/__/seeedtftfast_as.S.obj] Error 1
    [08:30:37][Step 4/8] make[1]: *** [PropWare/cmm/CMakeFiles/PropWare_cmm.dir/all] Error 2
    [08:30:37][Step 4/8] make: *** [all] Error 2
    Here is the line that caused the failure:
    jmp       #:loop
    edited 2015-04-08 08:20
    jmp       #:loop
    Has PropWare ever worked with the propeller-gcc repository? I don't think there were any chances in the assembler in my push last night.
    Also, I'll get the Windows cross build working tonight.
    edited 2015-04-08 08:29
    David Betz wrote: »
    No, it hasn't unfortunately.
    edited 2015-04-08 08:32
    Okay, this is probably due to using the new binutils. We should let Eric Smith know about this problem with colon labels. Is that the only problem you've seen with building PropWare?
    edited 2015-04-08 10:46
    David Betz wrote: »
    So far, with GCC4, yes. GCC5 still doesn't have C++ support, but you mentioned you're already aware of that so I'm not worried.
  • ersmithersmith Posts: 6,232
    edited 2015-04-08 10:54
    I think we switched over to the new binutils on the default branch a while ago, didn't we? Does it build with that?
    Where does CMake put its build output? I tried building PropWare and got a failure, but I'm not sure if it's the same one.
    edited 2015-04-08 11:00
    ersmith wrote: »
    The propgcc repository is still using the old binutils as far as I know. Only the propeller-gcc repository is using the new one.
    edited 2015-04-08 11:04
    ersmith wrote: »
    It builds with 2408. I haven't tried anything newer.
    ersmith wrote: »
    I don't think it logs verbose output. If you run make without arguments, you only get warnings and errors. If you run "make VERBOSE=1" then it echoes everything to stdout before running. I hope that answers your question... let me know if not.
    edited 2015-04-08 11:41
    I'm at a bit of a loss. The first time I tried to run INSTALL.py it failed at about 78%, but gave no error message. I went in to the bin directory and did "make", and it ran fine. I tried running propeller-elf-gcc directly on seeedtftfast_as.S, and it assembles without any error.
    If you do:
    propeller-elf-gcc -I.. -c seeedtftfast_as.S
    in the PropWare directory, does it work, or do you get the same error?
    Are you running a 32 bit version of Linux? If so, perhaps there's some kind of int/pointer size issue going on -- I have 64 bits here.
    Eric
    edited 2015-04-08 12:55
    ersmith wrote: »
    If you do:
    Eric
    Here's the result
    dzweb@davidzemonname:~/PropWare/PropWare$ propeller-elf-gcc -I/var/www/vhosts/david.zemon.name/PropWare seeedtftfast_as.S
    seeedtftfast_as.S: Assembler messages:
    The server is 64-bit Ubuntu 14.04. I'll try this on my local machine when I get home.
