C: Problems with atof and strtod fuctions within SimpleIDE
idbruce
I was always more an atoi kind of guy, but with this GCODE stuff and the floating points, I am now having to use the other available functions. Of course there could be a situation that I am unaware of, but this just seems very odd to me. In reference to the terminal output below, the upper line is the string representation and the lower line is the numeric representation. X, Y, Z, E, & F are all doubles and have been tested with both the atof and strtod functions, and both produce similar results.
Fileline: G1 X11.11 Y22.22 Z0.12 E0 F30000 Valid GCODE Fields: 10000111111 G: 1, X: 11.11, Y: 22.22, Z: 0.12, E: 0, F: 30000, G: 1, X: 11.110000, Y: 22.219999, Z: 0.120000, E: 0.000000, F: 30000.000000, Fileline: G1 X33.33 Y44.44 Z0.1 E0 F222 Valid GCODE Fields: 10000111111 G: 1, X: 33.33, Y: 44.44, Z: 0.1, E: 0, F: 222, G: 1, X: 33.330002, Y: 44.439999, Z: 0.100000, E: 0.000000, F: 222.000000, Fileline: G1 E1.23 F900 Valid GCODE Fields: 10000000111 G: 1, E: 1.23, F: 900, G: 1, E: 1.230000, F: 900.000000, Fileline: G1 X55.55 Y66.66 E0.0102 F555 Valid GCODE Fields: 10000110111 G: 1, X: 55.55, Y: 66.66, E: 0.0102, F: 555, G: 1, X: 55.549999, Y: 66.660004, E: 0.010200, F: 555.000000, Fileline: G1 X77.77 Y88 E0.1234 Valid GCODE Fields: 10000110101 G: 1, X: 77.77, Y: 88, E: 0.1234, G: 1, X: 77.769997, Y: 88.000000, E: 0.123400, Fileline: G1 X-11.11 Y-22.22 Z0.12 E0 F30000 Valid GCODE Fields: 10000111111 G: 1, X: -11.11, Y: -22.22, Z: 0.12, E: 0, F: 30000, G: 1, X: -11.110000, Y: -22.219999, Z: 0.120000, E: 0.000000, F: 30000.000000, Fileline: G1 X-33.33 Y-44.44 Z0.1 E0 F222 Valid GCODE Fields: 10000111111 G: 1, X: -33.33, Y: -44.44, Z: 0.1, E: 0, F: 222, G: 1, X: -33.330002, Y: -44.439999, Z: 0.100000, E: 0.000000, F: 222.000000, Fileline: G1 E-1.23 F900 Valid GCODE Fields: 10000000111 G: 1, E: -1.23, F: 900, G: 1, E: -1.230000, F: 900.000000, Fileline: G1 X-55.55 Y-66.66 E-0.0102 F555 Valid GCODE Fields: 10000110111 G: 1, X: -55.55, Y: -66.66, E: -0.0102, F: 555, G: 1, X: -55.549999, Y: -66.660004, E: -0.010200, F: 555.000000, Fileline: G1 X-77.77 Y-88 E-0.1234 Valid GCODE Fields: 10000110101 G: 1, X: -77.77, Y: -88, E: -0.1234, G: 1, X: -77.769997, Y: -88.000000, E: -0.123400, Fileline: G1 F1200 X0 Y0 Z23 Valid GCODE Fields: 10000111011 G: 1, X: 0, Y: 0, Z: 23, F: 1200, G: 1, X: 0.000000, Y: 0.000000, Z: 23.000000, F: 1200.000000, 11 total lines
55.55 string output
55.549999 numeric output after atof
Nope, I didn't know that.
Hmmm.... I was hoping the floating points would match for mathematical reasons instead of actual print, but I supoose rounding would do the trick.
That said, the strtod and printf functions that come with SimpleIDE are not very careful about precision, and do a poor job with very large and very small numbers. The ones in the default branch of PropGCC are quite a bit better, and the ones in the new proplib C library are better still.
Eric
I certainly thought that it should be identical to the string respresentation
I never really had the need to work with floating point numbers, except for perhaps percentages.
Bitmaps, screen resolution, control size, etc... were always in whole numbers.
Thanks again.
That works pretty darn good for the output. As for computations, I think I found some worthy snippets here: http://stackoverflow.com/questions/1343890/rounding-number-to-2-decimal-places-in-c
I do not understand for what you need floats at all. Your G code has two digits behind the decimal point. Multiply by 100 and use 32 bit integers.
float always introduces rounding errors. 0.1 + 0.2 is not equal 0.3.
my 2 cents
Believe me, I thought about going that route, BUT not all the floating points simply have two digits behind the decimal point, at which point, the parsing technique becomes much more lengthy, just to determine the exact location of the decimal point. However, I may end up going that route in the long run. My goal at this point is to keep the code very simple and short.
