Announcing the New P8X00A Propeller Chip
Announcing the P8X00A
Parrallax today announced the immediate, but limited availability of a new Propeller chip,
to be known as the P8X00A.
The new P8X00A propeller chip is based on the P8X32A...
* 8 x CPU Cores, 32bit CPU, 2KB private RAM/Registers, 2 counters, VGA/Composite video
* Each CPU Core is capable of operating at 100MHz
* 32KB shared RAM, accessible by all CPU Cores in round-robbin 1:16 clocks, byte/word/long access
* 32KB shared ROM, accessible by all CPU Cores (as per shared RAM), with SIN/LOG/FONT tables and Boot Code
* Internal Oscillator
* No External EEPROM
* Logical Object Oriented Familiar Language and Intelligent ReProgramming Algorithm (tm) means downloading is not required
* Available in user friendly small footprint 0.6"W DIP8
* 00 x Input/Output pins
Chop Gracy, the Chip's designer, said today that this development was done to satisfy the hobbyist market that
have been clamouring for a smaller, cut-down Propeller P8X32A, in a hobbyfriendly package.
Kon Gracy, Head of Marketing, said they expect these sales to far exceed the popular cut-down Propeller P8x16A.
Due to very limited availability, the P8X00A will only be made available to existing forum members.
A limit of one (1) P8X00A per member will apply until further stocks become available.
P8X00A US$5.00ea + US$10.00 p+p (limit 1 per customer).
┌──────────┐ Vss ─┤ ├─ Vdd BOEn ─┤ P8X00A ├─ XO RESn ─┤ ├─ XI Vdd ─┤ ├─ Vss └──────────┘
http://forums.parallax.com/showthread.php/149255-P8X16A-DIP24-16xI-O-Propeller-now-working-)?highlight=p8x16a
LOOFLIRPA sounds like a great language!
Happy March 32nd!!
I see this would be a great add-on for a Z80 board as it provides the oscillator and brown-out and reset functions all in one chip!! Since it is 0.6" wide I can place it inline with the Z80 and not compromise the address/data bus routing to my 2708 EEPROMs and 2102 RAMs. I'm guessing this part is only 3.3V so I might have to add some level translators but I don't mind adding more chips, it makes the board look complicated for those masses that gasp in wonderment at it.
But before I order my limited quantity of one (since I am a forum member), I'd like to see a photo of the chip please, and the datasheet too as I don't want to design it in before I RTM.
But wait! There's more! If you order in the next 15 minutes, I'll double your order, absolutely free! (Just add separate processing and handling.)
PreCOG advanced intent pipelining means you only have to plan on it happening and the PreCOG does the rest, and only requires proximity and power. No more burned pins, no more messy wires, no more muss, no more fuss!
Now you would normally expect one last pitch, one last call to action, but no more! It's shipping, and you know it, and it knows why. Check your mailbox today!
It has a unique "stacking" feature for easy expansion and is bipolar and 5V tolerant.
Are you going to offer a 'tri blade' version of these?
... as well as extremely low power with Heterogenous Special High-Efficiency ExtremeTechnology P8X00AHSHEET:
Does anyone understand what I am saying?
Here is proof of existence of my P8X00A
A 16 x I/O version with no Cores, no Memory and built using the latest ZeroPower(tm) technology
The pull-up he used was too strong!
Title: New Microchip Technology Harnesses Changes in Body Temperature to Keep Your Cellphone Charged…for 10 Years
Link: http://www.theblaze.com/stories/2015/03/31/new-microchip-technology-harnesses-changes-in-body-temperature-to-keep-your-cellphone-charged-for-10-years/ (BTW, it's an Atmel chip)
But it turns out that it wasn't a joke (though the headline took a little artistic license in saying "Your Cellphone").
The article links to a nice video showing the Cortex being powered by a warm cup or a hand to broadcast to a nearby radio using AM.
So just now I turned down the sensitivity of my skeptical setting and came here to my trusted Parallax forum and what did I find?
I found that intelligent people have a good sense of humor. Chop and Kon ought to get in on this.
Then again, what if Kon--or better yet, Ken--reported that a new chip really were in an advanced state of development. Call it the P2.
I suppose that someday chips won't need I/O pins and can be connected wirelessly when in close proximity, but I'll gladly settle for a P2 in the meantime.
