Color code tables for Propeller Video
Genetix
Several drivers state that Graphics Palette has a Color Code chart but I don't see anything in the code.
I am trying to decipher Chip's demos so I can use them but few of the colors are documented.
http://www.rayslogic.com/propeller/Programming/TV_Colors.htm
When bit[3] = 0, bit[2..0] are sent to the 3 bit DAC, giving 8 levels: -40 IRE (sync) to 100 IRE (bright white) in 20 IRE steps with 0 IRE being blank / black. (IRE is the scale used when measuring TV signals.)
When bit[3] = 1, the DAC is driven with the value in bit[2..0] +/-1 based on the MSB of bits 7-4 plus a 4 bit counter driven by PLLA. From the TV perspective, for bit[3..0] = 9 to 14 this looks like a -20 to 80 IRE luma signal with a 40pp IRE chroma signal riding on top (with the chroma phase set by bits 7-4). (Note: as -20 IRE is below black, bit[3..0] = 9 generally not used.)
The fun is when bit[3..0] = 8 or 15 as now the +/-1 causes an overflow so the output is -20/100 IRE and -40/80 IRE respectively which is then decoded as 40 IRE or 20 IRE luma with 120pp IRE chroma (three times the color saturation). However, this also creates a phase reversal, which is why it generates a different color.
If so, what are their byte codes?
The regular ones are: 08, 18 ... E8, F8
BTW: I think you also figured out how to use the other TV resistor to create more colors with a modified driver, right?
Colors 0F, 1F ... EF, FF are the other set of super saturated colors.
Yes, see http://forums.parallax.com/showthread.php/126099-more-colorful-baseband-TV for the TV driver using the auralsub pin to increase the colors. (Although it wasn't 100% stable on all displays.)
Eric
Usually it is just a resistor array forming a simple DAC for TV and direct pins for VGA?
Except the C3 board. There you have a chip to use either VGA or use the pins by yourself on the header.
Confused?
Mike.
https://www.parallax.com/sites/default/files/downloads/32900-Propeller-BOE-Schematic-Rev-A.pdf
https://www.parallax.com/sites/default/files/downloads/32900-Propeller-BOE-Bill-Of-Material-Rev-A.pdf
http://www.ti.com/lit/ds/symlink/sn74ahc541.pdf
The Human Interface Board uses a 74HC541.
https://www.parallax.com/sites/default/files/downloads/40003-Human-Interface-Board-Schematic-Layout-Rev-A.pdf
http://www.ti.com/lit/ds/symlink/sn74hc541.pdf
The VGA SIP Adapter uses a 74LVC541.
https://www.parallax.com/sites/default/files/downloads/28076-VGA-SIP-Adapter-Rev-A-Schematic-Layout.pdf
http://www.ti.com/lit/ds/symlink/sn74lvc541a.pdf
The older designs only had resistors.
https://www.parallax.com/sites/default/files/downloads/32100-Propeller-Demo-Board-Schematic-RevG_0.pdf
https://www.parallax.com/sites/default/files/downloads/32111-PPDB-RevA-Schematic.pdf (Last page)
https://www.parallax.com/sites/default/files/downloads/28075-VGA-PS2-Adapter-Board-A-Schematic.pdf
But looking at the schematics you provided I do not see any enable/disable function here like on the C3 board from Parallax.
So I am stumped and hope somebody with more knowledge could chime in.
As far as I know you do not need any buffers for VGA or TV. I started with a PE kit on breadboards and later used a lot of them 5-pack ProtoBoards(?) without USB. Never used any buffers there, and that was the beauty of it for me. Simple circuit and able to put out VGA or TV. The C3 was disappointing to me, since none of the usual drivers worked for SPI. Collecting dust now.
So now I am more confused then before I looked at them schematics.
Sorry to be of no help to you.
