Large or large-ish coil winding forms?
xanatos
I'm back after completing a three month programming project and looking to play a little before I dive into the next project!
I'm looking for some coil forms - I want to make a few Maxwell Coil arrangements as a side project - I'm looking for a source of nice circular coil forms in the 3 to 5" diameter range, and a few more in the 7 to 9" range, where the channel of the form would be around 1/4 to 3/8" thick... these can be plastic, as they will be subject to no significant heating, it's for me to do some playing with forming more complex fields, magnetic bottles, etc.
I searched for coil forms, large coil forms, etc., and have not had exactly stellar results. Mostly little ferrites & torroids, mostly RF stuff. I'm just wondering if anyone on here has a bead on anything similar.
If worse comes to worst, I can always cut out a bunch of circles & make a bunch of cross-connects to hold the two together and give me something to wind on, but the forms I have in mind I see in USE everywhere, but can't seem to find where people are actually getting them.
See image below for ideal form.
Thanks for your help/advice,
Dave
Dave
I'm unsure if it can fit your needs, but if you could find some ancient Super 8 film reels, I'd bet they can spare you from scratching your head a lot.
The following link lists the available diameters for the various reel types.
http://www.filmfix.com/super-8-normal-8-spule-erkennung-format.asp?l=e
Hope it could help a bit
Yanomani
Marty
loads of scrap circles (useful for other projects of course). The technique is to build up a
structure in layers of acrylic which you can then glue together.
This sounds like 3D printing could work out for you.
When I'm building things that need a particular shape I usually draw up what I want
using Sketchup, and send the design to someone
that has a 3D printer.
I use MakeXYZ.com
I found a pretty good guy that lives within 1/4 mile of where I do.
I found this to be a pretty good option lately.
gg
Here is a styrene coupling example.
http://makearadio.com/coils/cylindercoils.php
The pdf catalog.
http://genovaproducts.com/docs/PlumbingCatalog.pdf#page=9
Not exactly what you want, but close.
Sections of large diameter cardboard mailing tubes? Make flanges to fit on the outside diameter from plastic, thin plywood?
Various sizes of plastic buckets are available. The lack of a flange at the end is the part that's missing.
What is the frequency range?
So much easier than using any common or garden round thing that happens to be lying around
How on Earth did Helmoltz and co. get by without a 3D printer?
Appreciate the ideas!
Dave
Of course most of the readers may not know who that guy was. I believe I do, but it was a very long time ago.
What is the frequency range of your project?
DC to low frequency ac or pulsed dc. I'm making a few magnetic bottle configurations, just holding some plasma in place.
I'm curious to hear what you have in mind.
That said, there are containment devices all over the place - have you ever seen those little "Plasma Balls" you can buy at novelty shops? It's just not a very robust plasma
I even saw a video the other day of someone making a plasma "thingy" with a wine bottle (and a good vacuum pump & HV source)! I'll try to find the link http://www.quantumdiaries.org/2015/02/04/physics-wine-plasma-fun-2/ Please note step 1: Drink a bottle of wine.
I'm trying to make specific and stable shapes. And I can do this for cheap while I build up the funds for my next advance on my other more involved project
Ah, OK, cool. I'm all up for such experiments and demonstrations.
Be careful with that mixture of wine and high voltage power supplies!
