C language - rand() datatype (max value)
In one source I see Propeller C rand() generates from 0 to 2,147,483,647, implying data type of int.
But I generated 100k rand() values and got a range from 0 to 32767 implying a data type of short int, just the positives.
A general C reference said it depends on the implementation.
Can anyone confirm the data type, or why my test for max is 32767 instead of 2,147,483,647?
test code:
#include "simpletools.h"
int main(void)
srand(CNT);
int myRandNew=1; int countTrial=1;
int maxSoFar=1; int minSoFar=1;
for(countTrial;countTrial<=100000;countTrial++){
myRandNew=rand();
if(myRandNew>maxSoFar) maxSoFar=myRandNew;
if(myRandNew<minSoFar) minSoFar=myRandNew;
}//for
print("count of trials %d\nminSoFar=%d\tmaxSoFar=%d\n",countTrial,minSoFar,maxSoFar);
test code:
int main(void)
srand(CNT);
myRandNew=rand();
}//for
#define A 1103515245 #define C 12345 #define S 16 /* amount to shift before retrieving result */ int rand(void) { _TLS->rand_seed = _TLS->rand_seed * A + C; return (_TLS->rand_seed >> S) & RAND_MAX; }
RAND_MAX is defined to be 0x7fff. So rand returns an int that is between 0 and 32767."The rand() function returns a pseudo-random integer in the range 0 to RAND_MAX inclusive"
However it does not say what RAND_MAX might be.
It goes on to:
"POSIX.1-2001 gives the following example of an implementation of rand() and srand(), possibly useful when one needs the same sequence on two different machines.
static unsigned long next = 1; /* RAND_MAX assumed to be 32767 */ int myrand(void) { next = next * 1103515245 + 12345; return((unsigned)(next/65536) % 32768); } void mysrand(unsigned int seed) { next = seed; }
All in all I would never use rand(). Firstly because it is generally a really bad pseudo random number generator and secondly because it is not thread safe (for that you should use rand_r()).Like many C standard functions it is to be avoided.
Can you printf the value of RAND_MAX ? That will tell you something.
(yeti@aurora:8)~/wrk/propeller/propgcc/propgcc/lib/include$ grep -i rand stdlib.h #define RAND_MAX 0x7fff int rand(void); void srand(unsigned int seed);
... and reading lib/stdlib/rand.c ...
...looks like propgcc4's lib produces 15-bit random integers...
(propgcc4-1.9.whatsowver-version here...)
I tried below but rand_max not recognized (tried UC and LC). Do I have to do something more to "pull it out from the library"?
#include "simpletools.h" int main(void){ srand(CNT); int myRandNew=1; myRandNew=rand(); //print("\nrand_max = %d",RAND_MAX()); //print("\nrand_max = %d",rand_max()); print("\nrand_max = %d",rand_Max()); }
John Abshier
Wow thanks for the heads up on PGC. Melissa O'Neill's lecture on random number generators is a real treat for us random nerds.
I had not realized there were such recent developments in PRNGs and statistical tests for randomness. (TestU01)
Somewhere here I posted a Spin object for the jkiss32 PRNG, a version of George Marsaglia's KISS algorithm, which dates back to 1999 http://www.math.niu.edu/~rusin/known-math/99/RNG, looks like we now need a Spin / PASM PGC!
