Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
led defusers for the ws2812b — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Accessories
jdolecki
726
2015-03-19 20:46
edited 2015-03-21 07:30
in
Accessories
Does anybody found a diffuser to cover these led boards if I was to mount them inside an enclosure?
thanks john
WBA Consulting
2,938
2015-03-19 23:56
edited 2015-03-19 23:56
I have been using pieces of color gels from an
Apollo Gel Sample
set. Some of the white diffuser types work pretty well to blend the three elements.
Also, check craft supply stores for vellum material. I have used it in the past.
I also have a huge bag of inch long lightpipes somewhere from a surplus buy that are diffused just enough where they aren't called clear so I think they would blend well also, but haven't tried them out. On that subject though, Bivar makes quite few worth checking out:
http://www.digikey.com/product-detail/en/PLP5-2-125/492-1531-ND/2671096
http://www.digikey.com/product-search/en/optoelectronics/optics-leds-light-pipes/524541
Phil Pilgrim (PhiPi)
23,514
2015-03-20 12:22
edited 2015-03-20 12:22
Scotch Magic Tape, maybe? I've used that in a pinch.
rosco_pc
469
2015-03-21 07:30
Pingpong ball works quite well
Sign In
Register
to comment.
