NASA's testing its far-out electric plane concept
This sounds nuts to me -
Think there's a better way to spend their limited funds!
http://www.engadget.com/2015/03/17/nasa-testing-leaptech-wing/
NASA's set to test a wing concept it says "may herald (the) future" of electric planes, but it almost looks like a joke -- it has one-third the wing area of a normal aircraft and 18 electric motors. However, the space agency is dead serious about the LEAPTech wing, a joint partnership with two private aerospace companies. It consists of a 31-foot, carbon composite span with tiny motors powered by lithium iron phosphate batteries. After successful testing at slower speeds, NASA will "fly" a wing section aboard a specially-equipped truck at speeds up to 70mph. Eventually, the wing will be mounted to a commercial Tecnam P2006T aircraft and flown by test pilots
Better than basic research? Example, please. I'm all ears!
Not to take away from NASA, but they do realizes there are still DC3's and Piper Cubs flying that are 70 years old? People that have actually bought airframes with THEIR OWN MONEY try to make them last and may not be able to exercise their "transformational capabilities in the near term"
That's a skinny little wing! I wonder what kind of brick it glides like when you have no power to pull you forward and no little fans spinning to blow a breeze across your wing?
Betcha it lands faster if it loses power on final!
P.S. I'm going out to the rocker...... Dang kids! Get off my grass!!!
NASA - National Aeronautics and Space Administration
How does electric prop planes figure into Aeronautics and Space? Use it on the moon or mars? Maybe the next earth like planet we explore...
National Aeronautics and Space Act of 1958 (Unamended)
