Duration counter
Hello,
i have another question
what I am doing is running a repeat for 1 second, during that one second i collect data, then break out using a repeat while, then I post a message and reset for the next second of reading
the issue that seems to be occuring is that most of the time, I get 1 second intervals, but every so off i get a burst of messages, as if the repeat while is being by passed.
I thinik it is the way I set up the one second interval. loop and the test are wrong
Here is the code
I tried different ways, but the results is usually the same. most of the examples I have seen are using waitcnt for delays, but I want to process during the second, and not delay
regards
Jeff
Here is the code
{Object_Title_and_Purpose} CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 VAR long Transition_counter long pin_state long previous_pin_state long GPM long GPM_temp long Dt long record_number long t OBJ term : "FullDuplexSerial" fMath : "FloatMath" ' fMath : "Float32full" fString : "FloatString" PUB Main term.start(31, 30, 0, 115200) record_number := 1 t := 0 dira[8]~ ' set to input := 0 dT := clkfreq repeat term.tx(13) term.str(string(" Rec Num: ")) term.dec(record_number) record_number++ t := clkfreq + cnt ' get next second repeat while cnt < t ' loop until second is up pin_state := ina[8] ' check high or low if pin_state == previous_pin_state 'do nothing else previous_pin_state := pin_state ' make new pin state transition_counter++ ' and count the transision
regards
Jeff
works fine now, no runaway output
New code
old code (which did not work)
regards
Jeff
