Floating Point calculation
Hello,
I have a question on floating point,
I using floating point,
tMath : "FloatMath"
fString : "FloatString"
and performing this calculation
(0.1 * 13) / 13 which should give me 0.1 as output
but I am getting 0.07692308
Hz: 13 GPM: 0.07692308
I attached the code:
regards
Jeff
tMath : "FloatMath"
{Object_Title_and_Purpose} CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 VAR long Transition_counter long pin_state long previous_pin_state long GPM long GPM_temp OBJ term : "FullDuplexSerial" Math : "FloatMath" ' fMath : "Float32full" String : "FloatString" PUB Main | t term.start(31, 30, 0, 115200) dira[8]~ ' set to input := 0 'Hz is frequeny per second ' count the number of transisions from high->low->high repeat term.tx(13) term.str(string("Hz: ")) transition_counter := 13 term.dec(transition_counter) 'GPM := (0.1 * transition_counter) / 13 fmath.FFloat(transition_counter) GPM_temp := fmath.FMul(0.10, transition_counter) GPM := fmath.FDiv(GPM_temp,13) term.str(string(" GPM: ")) term.str(fstring.FloatToString(GPM)) GPM_temp := 0 GPM := 0 Transition_counter := 0 ' reset Transision counter t := clkfreq + cnt ' get next second repeat while cnt < t ' loop until second is up waitcnt(clkfreq/1000 + cnt) ' wait one millisecond pin_state := ina[8] ' check high or low if pin_state == previous_pin_state 'do nothing else previous_pin_state := pin_state ' make new pin state transition_counter++ ' and count the transision
regards
Jeff
Jeff
I think the line
should be
Bean
that yields
Hz: 13 GPM: 5.444519e+38
regards
Jeff
Oh, I see. I think this needs changed too. to
Basically you can't use integers ANYWHERE you are doing floating point stuff. Without using FFloat.
I'm not sure, but you might be able to just use 13.0 too.
Bean
P.S. Yes, I tried it. using 13.0 will work.
anyway, the changes
output is now correct
Hz: 13 GPM: 0.1
thanks for the help
regards
Jeff
The latest version (i think it's 1.6) is in the OBEX. F32 is also included in the archive attached to my integer vs floating point trig speed tests.
