2N2222 as phototransistor - not?
Many years ago I was desperate to try a "novel" opto switch circuit.
But it was late Saturday and I had no photo-transistor in my box.
So I've decided to make it out of 2N2222 by opening its metal T0-18 case.
The photoefect was week but enough to proof a concept, and It worked as expected... nearly.
However, it did not last for more then few trials after which my home made "opto's" kept dying,
as I kept cutting the tops of few more transistors to replace the dead ones
So my question was - and still is - why the "optotransistors" made out of exposed to light 2N2222 did not last?
Was this one busy dude or what!!!
Go Forrest, Go.
I was really surprised that an open transistor junction lasted no longer than few minutes.
Google for pictures of the very first experimental transistor with clearly visible and exposed plates/wires touching germanium.
https://www.google.ca/search?q=first+transistor&biw=1280&bih=871&tbm=isch&tbo=u&source=univ&sa=X&ei=mAgBVZiyNYH8oQSUmoHoAQ&sqi=2&ved=0CBwQsAQ#imgdii=_
No glass or else around it. Also, the very first crystal radios used to have a diode made out of pointy metal spike simply touching a crystal blob...
A couple of years before that Mullard made an early Ge transistor, the OC71, that was encased in glass with black paint on the outside. They also sold a much more expensive photo-transistor, the OCP71, which was identical, but without the black paint. Lots of people simply converted the cheaper device by scraping off the paint. Mullard got wise to this, and put the paint on the inside of the glass.
Now perhaps he did not continue his experiment long enough but he is the kind of guy who might notice if it fails after a while.
I find it hard to believe such an old style transistor would succumb to exposure to the atmosphere so quickly.
Back in uni one of our experiments was to make a silicon diode. A plate of n-type silicon with a blob of p-type fused on top. Or was it vice versa? Anyway, point is it lasted long enough to perform measurements on and was still working as a diode many months later.
I think I'm going to have to find an old 2N2222 and try this experiment.
The fact that it has an old part number does not necessarily mean it uses the old style manufacturing process. It could have been changed to fit a more modern process.production line.
Quite possibly true. That's why I say it's an experiment I'm going to have to have to try with an old transistor.
The 2N2222 setup was very simple - E to GND, and C via R=1k to +5V. The output (taken from C) was then directly DC-coupled to the base of another transistor (p-n-p this time).
I forced the photo-effect by shining a 60W 110VAC lamp directly into the TO-18 opening from a very close distance (perhaps not more than 10inches) .
Every time the transistor lasted no longer than few trials.
... 2N3055 as photovoltaic cells
https://www.youtube.com/watch?v=gRY7Re-Q0WI
https://www.youtube.com/watch?v=bGO5KIikKWA
