Arrgh! Prop Mini Wiring Messup
I soldered up my Prop Mini, and plugged a Prop Plug in DIRECTLY. Only after failed communication attempts did I consult the datasheet and see that the serial com pins aren't actually in the correct order !!!
Did I completely ruin the chip?
And WHY did Parallax do such a thing?!
Not necessarily. Just rewire it and try it.
It helps with visual identification of correct orientation.
While we're here, does anyone know if the HYDRA EEPROMs are significantly different from the one on the Prop Mini?
Code which uses the EEPROM and works on the HYDRA is failing on the Mini, and YES I did remember to change the CLKMODE and XINFREQ.
Curiously, the FSRW driver (the standard one) did not function correctly on the HYDRA, EXCEPT for the Exec() method.
Very strange.
