Design Help
I am sketching out the design for an event monitor that will detect eight channels of analog and sixteen channels of digital signals.
A real-time clock will be needed to mark the events.
A USB-2 or -3 jump drive memory will be needed for writing, reading, and erasing data.
An LCD display will be used to show that the unit is armed and operating.
The USB memory will be removable and readable by a laptop computer for extensive data analysis.
I would like to build the monitor using a Propeller Multicore processor.
Has the Propeller been used to interface with USB memory...if so, how would I proceed with the design?
Has an accurate real-time clock been implemented in a COG...if so how?
Sincerely.
Discovery
Sincerely.
Discovery
It's easy to connect Propeller directly to SD card using four pins.
Look for FSRW in forum or OBEX for details.
You can use a COG as RTC and it would be pretty accurate.
But, you'd have to reset the time if you cycled power.
There is a link to a Prop only RTC here:
http://www.rayslogic.com/propeller/Programming/Programming.htm
You don't mention your bandwidth requirements for logging, but I'd strongly suggest you start there in terms of your per-channel datum size, samples per second and file format overhead and determine the aggregate bandwidth you need to sustain to lay down your file.
Good luck.
It's not possible to use USB-2 or USB-3 directly with the Propeller. There has been some code posted here that uses some shortcuts with USB-1.1 to interface directly with HID and memory devices, but it's not standard USB-1.1 protocol and it's fairly slow.
The newer VDRIVE3 uses a more recent, more powerful Vinculum chip, the VNC2 rather than the older VINC1L. It has a larger buffer, faster processor and therefore higher throughput. It is by and large backward compatible at the communications layer. The VDRIVE3 is a very nice option for mechanical integration onto a front panel.
The footprint of the original SD card driver, FSRW, is 1005 longs, a bit more than 3% of Prop memory. That is the base, before you start integrating it into a project. I use bst, which does not compile unused methods into the footprint. In that case the footprint increases as you build your application. Wayne, I'm wondering where you came up with the 23% figure?
Figure less than 5KB/s for data rate. The device will be armed for a transition on an analog channel or digital channel and once triggered...all channels will be read along with the real-time clock and stored in memory.
I figure that with this Propeller based monitor...I can instrument the vehicle and eventually determine the cause of the problem.
I could use the SD card since it has driver software developed for use on the Propeller Activity Board. Good call.
I would like to change the real-time clock design requirement to be stand-alone and be kept alive with a battery on the PC Board. What would you recommend?
What about the LCD Display...will that be a problem?
Sincerely,
Discovery
Tracy 1000 longs is not 3% of 32kByte memory, more like 12%. But this is still a lot lower than the 23% or 25% that ksltd mentoined several times here and in other posts. Perhaps he uses the FAT-Engine which is much bigger than FSRW.
You can do optimized versions for read only or with smaller SPI drivers (even slow Spin SPI) then it goes down to something like 600..650 longs (8%).
And it's also possible to access the SD sectors without a FAT filesystem then I guess it is more like 400 longs but I have no real numbers for that.
Andy
Results reported by the FSRW speed test program:
Block write 895 kb/s
Block read 440 kb/s
Buffer write 523 kb/s
Buffer read 438 kb/s
Putchar 14 kb/s
Getchar 17 kb/s
The complete SD card drivers, the virtual memory layer, and the FAT32 drivers and utilities (dir ls append print save/load rom etc) take up around 4,800 bytes or 1200 longs.
