What analog Electronics Simulation Software does everyone use? and why?
Bob Lawrence (VE1RLL)
What Spice based analogue electronic simulation software does everyone use? and why?
New Wave Live Wire ( inexpensive ) I started with this one and it is easy to use but limited .
http://www.new-wave-concepts.com/pr/livewire.html
Linear - (FREE) LTSpiceIV (then I started to use this one and still use it)
http://www.linear.com/designtools/software/#LTspice
TI.com - Tina (FREE) ( I've had a look at this one but have not tried much)
http://www.tina.com/
Digikey - Parts Sim (FREE) ( I tried one design with this software - I's easy to use but too limited( under development)
http://www.digikey.ca/en/resources/design-tools/partsim
B2.Spice A/D Windows Version 2014 ( I tried the trial a few times and it works good but is too expensive for the few times a year I use software like this)
http://www.beigebag.com/?
Not being a professional circuit designer I'm not inclined to pay for such things.
Anything that won't run on Linux is of no use.
http://www.simetrix.co.uk/site/index.html
It's very good, with good support
It's integrated with the Pulsonix PCB software that I use.
I like it as well however, I've never tried it on Linux. I'll put that on my list of to do list.
@phil
re: for those very rare times when I need to simulate a circuit.
I don't simulate that often either. Most of the time I find it easier and faster to build the circuit on a breadboard and test it in the real world rather than simulate.
@Leon
re:I use SIMetrix Spice
Thanks! I'm downloading it now to try it .
I think it was Steve Ciarcia who said that his favorite software was solder -- or something to that effect.
Yes he did. Quote attached
Ciarcia's Circuit Cellar, Volume 7
From " A Supercomputer" 12
http://www.ti.com/ww/en/bobpease/
It's possible Ciarcia was quoting Bob.
Plus there's this clever way of remembering Bob:
http://blog.atmel.com/2013/09/19/bob-pease-says-my-favorite-programming-language-is-solder/
This is a ROM from an HP9100A calculator.
In fact, such diode array ROMS, although smaller, are used to program the conflict matrix of many old traffic light controllers that are still in use around the world.
Mind you, I don't think that is the kind of programming Bob had in mind.
I'm always weary, of the accuracy of the results. Spice is a lumped element simulation, in reality your circuit is a big wobbly eletro-magnetic jelly, a continuum of capacitance, inductance and resistance where all parts can interact with all other parts in unexpected ways. More so as frequencies go up. A simple case is the decoupling capacitor, Spice does not care where you place your capacitor or how long and wide the traces are to it. Reality does!
More often I just find myself just playing with Spice. When I find some new circuit configuration I have never heard of before it's nice to be able to build one in simulation and play around with it, just for fun and learning.
Or wary of the....? Reader beware. Either way, electronics simulation software can be very demanding to use. The actual program, and the quality of the componet database are big issues.
While everyone provides the right stuff for resistors, coils, and capacitors; the non-linear devices such as op-amps, transistors, and MOSfets get tricky to acquire good data.
Electro-magnetic jelly? Mmmm.... delicious. The world is full of estimates, guess-timates, and trash. The simulations are only a good as the user and his sophistication.
I have tried several versions of Spice offered in Linux. They mostly seemed incomplete and terrible. I don't think I tried LTSpice.
I suspect that getting a version from TI or Linear Technologies or such means much better data and better long-term support as this is a sales tool for them.
My overall impression was that one needed Windows or OSX to acquire the good ones. Linux users have to resort to installing WINE. TINA may be independent of the OS and cloud based, but wants money.
Ok then my favorite debugger is Desoldering Braid
@ Loopy Byteloose
re:TINA may be independent of the OS and cloud based, but wants money.
There is a cloud version that's a paid ver but they have a desktop version that's free
re:The simulations are only a good as the user and his sophistication.
or her
LOL Good one Bob.!
As you say the simulator is just fine in terms of accuracy, it's just that what it is modelling is perhaps not what you are building. A capacitor, famously has equivalent series resistance and inductance. I'm not sure how many capacitor models take this into account. Same goes for inductors and resistors, every component has second order effects that may not be in the models you are using.
Then how many people build models of their PCB traces and other interconnects into their simulations? Those connections are also components. They also have R and C and L. They are also coupled to each other via electric and magnetic fields. How many people bother to take all that interaction into account?
So yes, to make a sensible and accurate simulation one has to understand the limitations of the models in use. Especially as frequencies or impedances go out of limits where the lumped circuit element model works. Second order effect and all that.
LTSpice is a bit special because many years ago Mike Engelhardt came up with a way to speed up the maths of the simulation by a great deal and then went looking for someone to market it. Ending up at LT. It's not just the progiginal Spice code from UCB wrapped up in a GUI like many others have been.
The Windows limitation is a pain. As it is is so many other application areas.
Coincidentally Fran Blanche just released a video describing "diode steering" and demoing the idea with a decade to 7-segment decoder built from diodes: https://www.youtube.com/watch?v=JNbDdnEpAOQ
Now, what I want to do is build the boot ROM for CP/M on the Propeller using a matrix of LEDs. Then we can watch it boot up!
Back then we simulated our logic on paper !! ... and we liked it !!
For an assignment in an early electronics class we had to demonstrate our knowledge of designing with logic gates. Here is a design that I was able to fit into something the size of a pack of cigarettes including the battery. The design had a 60Hz time base that I divided down to 10ths of a second or 1 second clocks, or you could manually clock the counter. A 7447 BCD to 7-segment was used, but to get the LED's on the seven segment to display HEX, it was necessary to decode the remaining BCD with discrete logic gates since the 7447 would only go from 0 to 9 .... In order to do this DIODE ROM was used to get "A" "b" "C" "d" "E" and "F". I got an "A" on the assignment. :-)
http://bscircuitdesigns.com/Electronics.JPG
a component, rather than the worst-case behaviour (which is of course context-dependent),
giving an unrealistically optimistic result.
I tend to think designs through worrying about the worst case for each stage, so that there
are no unpleasant surprises (ie you assume the transistor has a gain of only 100 when the model
assumes 300, you assume the opamp offsets are the worst case in the worst directions...)
So my software of choice is brain, pen, calculator, back of envelope...
BTW, you left napkins off the list ;-)
re: Quote Originally Posted by Bob Lawrence (VE1RLL) View Post
re: my favorite programming language is solder
re: LOL Good one Bob.!
In 50 years people are going to ask I wonder who came up with that line and they will get a reply like " oh that was a Prop head guy named Publison" LOL
@Beau
re:Found It !! My Diode ROM application ( 1991 ) ...
It sure took allot of chips for that design. How things change
