Using TCS3200-DB with BS2OEM
Hello,
I have recently acquired the task of detecting the color of a bi-color LED, and I was thinking of using the TCS3200-DB (Parallax 28302) interfaced to a BS2 OEM. The LED has 2 colors, green (565nm) and yellow (590nm), and I would need to detect whether the LED is green, yellow, or OFF. The sensor could be fixtured to be within about 1/2" of the LED but it will be viewing from the side, not the top. Has anyone tried such a thing before? WOuld it work with the BS2 OEM or should I try something else?
MrSparkle
MrSparkle
You guessed it, the pins are inaccessible. I guess I could just buy the sensor and try it, I just wanted to make sure there was no problem with using the BS2 OEM for testing.
thanks,
MrS
http://www.parallax.com/sites/default/files/downloads/28123-Whats-a-Micro-v3.0.pdf
What about diverting the light to your sensor using a light-pipe?
I see light pipes used in electronic products all the time.
Genetix is spot on about eliminating ambient light. This would work best if a person doesn't actually have to see the LED. Then you could completely shroud it so that the sensor would respond only to the illumination.
