data logging
I am still new to the prop. I am trying to do some data logging with the prop and do some post processing in MatLab. The current code I have saves to binary. I want to know is there a way to save to an SD Card in ASCII. I have code that reads .CSV files in MatLab from old Arduino code I had for data logging. Any help would be great. Below is my current code
#include "simpletools.h" // Include simpletools header
int MISO = 12;
int SCLK = 13;
int MOSI = 14;
int SS = 15;
// SD card pins on Propeller BOE
// DO = MISO
// DI = MOSI
// CLK = SCLK
// CS = SS
// red wire is DO : pin 12 (MISO)
// black wire is SCLK : pin 13 (SCLK)
// yellow wire is DI : pin 14 (MOSI)
// green wire is CS : pin 15 (SS)
int main(void) // main function
char data [8] = {'2', '3' , '5', '7', '11', '13'};
int mout = sd_mount (MISO, SCLK, MOSI, SS);
print("%d \n", mout);
FILE* fp = fopen("test.txt", "w"); // Open a file for writing
//fwrite("Hello World....", 1, 15, fp); // Add contents to the file
for (int i=0;i<3;i++)
fwrite(&data, 4, 8, fp); // Add contents to the file
fclose(fp); // Close the file
char s[8]; // Buffer for characters
fp = fopen("test.txt", "r"); // Reopen file for reading
fread(&s, 4, 8, fp); // Read 15 characters
print("First 15 chars in test.txt:\n"); // Display heading
print("%s", s); // Display characters
print("\n");
pause(500);
while (1)
fwrite is going to be smaller than fprintf - but as you noticed, it needs a little bit of help to put the data in a more meaningful format. My suggestion: if you're trying to get every last byte of RAM back, then write your own function to convert integers to strings then log the data with repeated calls to fwrite. If the only format character you ever use is %d, then fprintf is going to pull in a lot more than you need.
PropWare's Printer class could help you with this actually. Instructions for using PropWare's Printer class follow:
Create a file named sdprinter.h with the following contents:
#include <PropWare/printcapable.h> // You may want to change this include to be the path that printcapable.h is in #include <stdio.h> #include <string.h> class SDWriter : public PropWare::PrintCapable { public: SDWriter (const FILE *file) { this->m_file = file; } void put_char (const char c) const { fwrite(&c, 1, 1, this->m_file); } void puts (const char string[]) const { const size_t length = strlen(string); fwrite(string, 1, length, this->m_file); } private: const FILE *m_file; };To use it, you'll also need to copy the file "printer.h" from PropWare into your project (assuming you're building using SimpleIDE)
You'll need to rename your main class from *.c to *.cpp, since it now uses C++ classes. And here's the Printer class in action.
#include "simpletools.h" // Include simpletools header #include "sdprinter.h" #include "printer.h" int MISO = 12; int SCLK = 13; int MOSI = 14; int SS = 15; int main(void) // main function { int mout = sd_mount (MISO, SCLK, MOSI, SS); print("%d \n", mout); FILE* fp = fopen("test.txt", "w"); // Open a file for writing // Create our writer... SDWriter sdWriter(fp); // And wrap it in the common printer class PropWare::Printer sdPrinter(&sdWriter); // Pick _one_ of the following two lines sdPrinter.printf("Hello World %u,%u,%u", 2, 3, 11); // This one uses syntax you are already familiar with sdPrinter << "Hello World " << 2 << "," << 3 << "," << 11; // This one uses less code space fclose(fp); // Close the file return 0; }You can save more space by eliminating the use of Parallax's print and switching it out for another Printer/PrintCapable object like so:
#include "simpletools.h" // Include simpletools header #include <PropWare/printer/printer.h> class SimpleWriter : PropWare::PrintCapable { void put_char (const char c) const { putChar(c); } void puts (const char string[]) const { putStr(string); } }; int main(void) // main function { const SimpleWriter serialWriter(); PropWare::Printer serial(&serialWriter); // Highly efficient serial.println("Hello world!"); // Equally efficient serial.printf("Hello world!" CRLF); // Note the explicit use of "CRLF" to add a newline // This pulls in a large chunk of code because it's the first time a parameter is used serial.printf("Hello, %s!" CRLF, "David"); // This is your best bet - it pulls in *exactly* the amount of code you need and *none* of the code that you don't serial << "Hello, " << "David" << "!" CRLF; }Notice how writing to the SD card and writing to the serial terminal use the same PropWare class: the PropWare:: Printer. This means the formatting functions (converting ints to strings, converting floats to strings, etc) are shared. This saves a lot of code space.
You could bring it all together with a main file like so:
#include "simpletools.h" // Include simpletools header #include <PropWare/printer/printer.h> // Serial console class SimpleWriter : public PropWare::PrintCapable { public: SimpleWriter () {} void put_char (const char c) const { putChar(c); } void puts (const char string[]) const { putStr(string); } }; // SD card class SDWriter : public PropWare::PrintCapable { public: SDWriter (const FILE *file) { this->m_file = file; } void put_char (const char c) const { fwrite(&c, 1, 1, this->m_file); } void puts (const char string[]) const { const size_t length = strlen(string); fwrite(string, 1, length, this->m_file); } private: const FILE *m_file; }; int MISO = 12; int SCLK = 13; int MOSI = 14; int SS = 15; int main(void) // main function { // Serial console const SimpleWriter serialWriter; const PropWare::Printer serial(&serialWriter); serial << "Hello, world!" CRLF; serial << "Mounting SD card... " CRLF; int mout = sd_mount (MISO, SCLK, MOSI, SS); serial << "Mount status (0 == success): " << mout << CRLF; serial << "Opening file" CRLF; FILE* fp = fopen("test.txt", "w"); // Open a file for writing // SD Card const SDWriter sdWriter(fp); const PropWare::Printer filePrinter(&sdWriter); serial << "File opened (stored in address " << (unsigned int) fp << ") " CRLF; filePrinter << "Hello " << 2 << ',' << 3 << ',' << 11 << '\n'; serial << "File modified" CRLF; fclose(fp); serial << "File closed" CRLF; return 0; }
