FT231XS com-port drivers for Linux kernel 2.6?
We have an old LIDAR system at work that's running Linux kernel 2.6 and we're having a hard time finding virtual com port drivers that support the new FT231XS chips on the quick-start boards. Anybody know of a way to get the FT231XS chips working without upgrading the kernel? (Upgrading the kernel is likely to brake a lot of your custom code, so we'd prefer to avoid the upgrade)
Marty
Marty
It doesn't seem too difficult to backport just the changes for FT231XS to the 2.6.x kernels.
-Tor
In any case, the lastest kernel driver has some subtle differences in the driver model which may prevent a simple source drop-in replacement. But the changes necessary for supporting the FT231XS are not so large and could be applied to the 2.6.x driver.
-Tor
Or drivers can be compiled as loadable modules.
Either way that driver code is relies on the internal API's (If that is the right term) of the Linux kernel. At run time they run in "kernel space".
All in all we can think of it as "kernel compile". It's the same in the Windows world.
Anyway, what is this Linux running on? I can't help thinking it would be better to get your code running on a newer Linux install rather than messing around with historic stuff.
I have had an ongoing problem with one of our drivers, keeping it working with new versions of Linux as they arise. I'd hate to be doing that work backwards!
Of course it would be better if the Quick start stopped using FTDI devices. Those things are not USB standard serial devices and their manufacturer has been known to distribute malware in it's driver.
To me, a module is a program that's just accessing another API, or rather, DPI, hehe. Like DX is another API alongside Win32.
Well, OK, yes. Compiling a kernel module is not compiling a whole kernel.
However that kernel module you have compiled will require root privileges for you to load it into a running kernel.
When it is loaded it is part of the kernel.
At that point, the code you have written in the module can totally mess with anything on your machine.
So any little bug in there and it can be poof! Light's out for you OS.
Or if you have obtained your driver from elsewhere, it can be any kind kind of malware that the provider puts in there. Like the recent USB device killing malware provided in USb/serial drivers by FTDI.
Same as in Windows as far as I can tell.
First, the Lidar we wanted to use the FT231XS chip with has 7 custom PCI boards with custom kernel drivers that do photon-counting. Porting that to a new Linux kernel is a LOT of work. We have the custom drivers working on Centos 5 and 6, though this system is one of our oldest so still ran Centos 5. (with Kernel 2.6.18)
Testing narrowed the failure down to a combination of Centos 5 and the specific industrial PC motherboard used in the LIDAR. Centos 6 worked on a newer Lidar upstairs. Centos 5 worked in a VM when hosted on a Mac laptop and Centos 6 PC. The final solution was to move this old Lidar to the newer Centos 6 distribution that we had running another lidar.
Marty
