Looks like heat shrink to me!
What is the difference between Sleev and standard shrink tubing?
The main differences between Sleev and standard heat shrink include the quality. The quality of standard heat shrink is generally lower as compared to that of Sleev. Also, once Sleev is placed on the wire, the center is rigid while the ends remain flexible, allowing for free movement while protecting the integrity of your wire. This free movement is possible because of the several different shrink ratios found throughout Sleev, which is not found in standard heat shrink.
Kickstarter: Sleev
360% Funded!!!
P.T. Barnum is proud!
Four bucks for 2 pieces of heat shrink. Give me a break! Unless there is something magical about this product.
Yes, one born every day.
This is one of the most absurd KickStarters I've seen.
I now use all those standards myself when bulding: (Thanks for the link)
http://workmanship.nasa.gov/lib/insp/2%20books/frameset.html
I've been using transparent heat shrink for several years, Now normal heatshrink looks barbaric.
I don't make any claim this is a rational opinion. I've just been very surprised how much more I like transparent heat shrink than opaque heat shrink.
No, I changed my mind. I claim this is a rational opinion. Opaque heat shrink hides the joint and I think it looks barbaric.
If you want to do the job properly you lace up your cables:
Those were the days. I don't know how many miles of lacing I did in my NZ Telecom days. Quite satisfying though getting it all evenly spaced.
I don't recall seeing lacing mentioned in the NASA workmanship guide but I think it's safe to assume it's also NASA approved.
I'll find it.
http://forums.parallax.com/showthread.php/143542-Self-Portrait-of-Curiosity-by-Rover-s-Arm-Camera
I think there's a better picture showing the laced cables. I'll post a link if I find it.
Edit: This site has some good pictures of Curiosity's knots.
http://igkt.net/sm/index.php?topic=4028.0
...been done already; used it many times in a previous job.
ATUM
This adhesive-lined, heat-shrinkable tubing provides sealing and strain relief. The tubings internal adhesive coating melts and flows to form the seal.
http://raychem.te.com/CableProtection.asp
+1
Used it myself but I couldn't remember the manufacturer.
Fortunately there were plenty of comments pointing out the similarities between Sleev and heat shrink tubing.
Apparently they had released a video of the real product but it has since been marked private.
And they STILL were overfunded by the Kickstarter crowd. Too bad they didn't have more colors to offer, they could have reached several stretch goals!!!
So, lets see, 3M adhesive lined 1/2" Polyolefin tubing is $242 for 12 pieces that are 48" long. These sleev gimmicks are about 3" long, so (12*48)/3 equals 192 pieces. Sold as a pair, so net is 96 pairs for $242 and ends up $2.50 a pair for QUALITY, PROVEN, BACKED, and SUPPORTED product.
http://www.shop3m.com/3m-heat-shrink-multiple-wall-polyolefin-tubing-eps400-450-48-black-12-pcs-48-in-length-sticks.html?WT.ac=US_EnterpriseCatalog_EPS400-.450-48%22-Black-12%20Pcs
The worst thing about the Kickstarter is that their recommended method for shrinking is a lighter. Really!?!?! Have they ever used adhesive lined tubing? Even heating ensures proper flow of the adhesive.
Thank you. It's good to know that such skills are reaching out there. What beautiful pictures!
Yes, but their heat shrink tubing comes packaged in recycled paper.
Not only is the paper recycled, it's also transparent.
You're very welcome. I agree they are beautiful pictures.
