Looks like heat shrink to me! — Parallax Forums
mindrobotsmindrobots Posts: 6,506
edited 2015-02-23 16:41 in General Discussion
What is the difference between Sleev and standard shrink tubing?
The main differences between Sleev and standard heat shrink include the quality. The quality of standard heat shrink is generally lower as compared to that of Sleev. Also, once Sleev is placed on the wire, the center is rigid while the ends remain flexible, allowing for free movement while protecting the integrity of your wire. This free movement is possible because of the several different shrink ratios found throughout Sleev, which is not found in standard heat shrink.
Kickstarter: Sleev
360% Funded!!!
P.T. Barnum is proud!
    edited 2015-02-23 11:35
    I don't trust anyone who can't spell sleev or strech.
    edited 2015-02-23 11:39
    mindrobots wrote: »
    Kickstarter: Sleev
    360% Funded!!!
    Four bucks for 2 pieces of heat shrink. Give me a break! Unless there is something magical about this product.
    Yes, one born every day. :)
    edited 2015-02-23 11:52
    I prefer the "Lucky Number Slevin". Sadly blocked on YouTube.
    edited 2015-02-23 11:56
    Don't use Sleev on anything you're building for NASA. They require transparent heat shrink tubing.
    This is one of the most absurd KickStarters I've seen.
    edited 2015-02-23 11:59
    Duane Degn wrote: »
    I now use all those standards myself when bulding: (Thanks for the link)
    http://workmanship.nasa.gov/lib/insp/2%20books/frameset.html
    edited 2015-02-23 12:20
    Publison wrote: »
    I now use all those standards myself when building: (Thanks for the link)
    I've been using transparent heat shrink for several years, Now normal heatshrink looks barbaric.
    I don't make any claim this is a rational opinion. I've just been very surprised how much more I like transparent heat shrink than opaque heat shrink.
    No, I changed my mind. I claim this is a rational opinion. Opaque heat shrink hides the joint and I think it looks barbaric.
    edited 2015-02-23 12:55
    Heat shrink, transparent heat shrink, bah, humbug!
    If you want to do the job properly you lace up your cables:
    edited 2015-02-23 13:32
    Heater. wrote: »
    Those were the days. I don't know how many miles of lacing I did in my NZ Telecom days. Quite satisfying though getting it all evenly spaced.
    edited 2015-02-23 13:46
    I'm sure most of you have seen the lacing done on Curiosity?
    I don't recall seeing lacing mentioned in the NASA workmanship guide but I think it's safe to assume it's also NASA approved.
    edited 2015-02-23 14:08
    Duane Degn,
    No, do you have any links to such things?
    edited 2015-02-23 14:12
    Heater. wrote: »
    Duane Degn,
    I'll find it.
    edited 2015-02-23 14:14
    Make sure and zoom in on the picture Ron links to in post #3.
    http://forums.parallax.com/showthread.php/143542-Self-Portrait-of-Curiosity-by-Rover-s-Arm-Camera
    I think there's a better picture showing the laced cables. I'll post a link if I find it.
    Edit: This site has some good pictures of Curiosity's knots.
    http://igkt.net/sm/index.php?topic=4028.0
    edited 2015-02-23 14:21
    mindrobots wrote: »
    ...been done already; used it many times in a previous job.
    ATUM
    This adhesive-lined, heat-shrinkable tubing provides sealing and strain relief. The tubing’s internal adhesive coating melts and flows to form the seal.
    http://raychem.te.com/CableProtection.asp
    edited 2015-02-23 14:30
    davejames wrote: »
    ATUM
    +1
    Used it myself but I couldn't remember the manufacturer.
    edited 2015-02-23 14:49
    davejames wrote: »
    Fortunately there were plenty of comments pointing out the similarities between Sleev and heat shrink tubing.
    Apparently they had released a video of the real product but it has since been marked private.
    edited 2015-02-23 15:01
    Duane Degn wrote: »
    And they STILL were overfunded by the Kickstarter crowd. Too bad they didn't have more colors to offer, they could have reached several stretch goals!!!
    Duane Degn wrote: »
    edited 2015-02-23 15:59
    Wow, absolutely ridiculous KickStarter!!!! $4 for two pieces of glue shrink.... and people fell for it!!!! That is the scary part. Since they don't claim to be making the shrink, my guess is that they are buying a full roll of glue shrink from a reputable source (3M, Raychem, etc) and just cutting it into pieces.
    So, lets see, 3M adhesive lined 1/2" Polyolefin tubing is $242 for 12 pieces that are 48" long. These sleev gimmicks are about 3" long, so (12*48)/3 equals 192 pieces. Sold as a pair, so net is 96 pairs for $242 and ends up $2.50 a pair for QUALITY, PROVEN, BACKED, and SUPPORTED product.
    http://www.shop3m.com/3m-heat-shrink-multiple-wall-polyolefin-tubing-eps400-450-48-black-12-pcs-48-in-length-sticks.html?WT.ac=US_EnterpriseCatalog_EPS400-.450-48%22-Black-12%20Pcs
    The worst thing about the Kickstarter is that their recommended method for shrinking is a lighter. Really!?!?! Have they ever used adhesive lined tubing? Even heating ensures proper flow of the adhesive.
    edited 2015-02-23 16:25
    Duane Degn,
    Thank you. It's good to know that such skills are reaching out there. What beautiful pictures!
    edited 2015-02-23 16:39
    Yes, but their heat shrink tubing comes packaged in recycled paper.
    Not only is the paper recycled, it's also transparent.
    295 x 310 - 28K
    540 x 141 - 29K
    Heater. wrote: »
    Duane Degn,
    You're very welcome. I agree they are beautiful pictures.
