Parallax TurboROM
Soooooo..... by any chance does anyone know if the old (circa 1992) Parallax TurboROM supports 2716 or 2732 eproms? I have a chance to buy one but the seller doesn't know much about it and I cannot find a spec sheet on the web. I work primarily with old 2716 eproms.
Tim
Tim
A lot of equipment I was involved with years ago used 2708/16/32 eproms, and I still have a bunch of them. Is the TurboROM an eprom programmer or perhaps a ram based eprom emulator?
Thanks!
If you only want to emulate 2716/32 eproms you can probably do that with a propeller and 2 or 3 buffers/level translators. May not even need the buffers for some applications.
If you also want to upload and and program eproms that can also be done but it is a bit more complicated. I built one from an old magazine project using a Z80 many years ago so for sure the propeller can handle that.
I just want to emulate. I'm trying to avoid taking on another project just to support a project .. But maybe I'll need to look into designing an emulator. Thanks!
Isn't that just a simple adapter header, to go into the subset socket ?
It's usually a bit more than that. An emulator can be a simple battery backed sram and a bit of logic that allows it to be programmed by the eprom programmer or a unit that sits in the eprom socket and can be reprogrammed while it is in the circuit. A propeller would be great as an in circuit eprom emulator for such old eproms. It has enough I/O, memory, and speed for the task. The only thing it might need is a buffer/level translator for the data bus.
