AMC0802B LCD
I have a nifty little project I'm working on and thought it would be the perfect time to learn the Propeller. I found a decently priced little LCD that I would like to use instead of the serial lcd from Parallax due to size and cost. The C tutorials are pretty good but I am a little confused with SPI interfaces. I believe I can get the display initialized, but I can't figure out the best way to send the actual data to the display based on the datasheet. Do I send each individual character to the DDRAM address for its position in the display?
I have some experience with Stamps, but am completely new to the Propeller platform. I'm using SimpleIDE. I may have bitten off more than I can chew, but I tend to be a feet first kind of person.
Thanks!
Al
/* Oriental Display - AMC0802B-SPI */ #include "simpletools.h" // Include simpletools lib int lcd_csb = 6; // Chip Select int lcd_sid = 7; // Data int lcd_sclk = 8; // Clock int lcd_rs = 9; // Register Select int main() // Main function { pause(42); // Wait at least 40ms high(lcd_csb); // CS line high high(lcd_sclk); // CLK line high low(lcd_csb); // CS -> low start SPI pause(10); //Initialize LCD shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00111000); // Function Set - 8bit, 2 Line, 5x8 pause(1); // Wait at least 100us shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00001100); // Display On pause(1); // Wait at least 100us shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00000001); // Clear Display pause(12); // Wait at least 10us shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00000100); // Entry Mode Set pause(1); high(lcd_csb); // CS -> high stop SPI pause(10); //Send it a Character high(lcd_csb); // CS line high high(lcd_sclk); // CLK line high low(lcd_csb); // CS -> low start SPI shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b11000000); //Set DDRAM Address shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00010100); //Generate "A" }
Thanks!
Al
Hi
In answer to your question about character placement - Yes.
The AMC0802B is HD44780 compatible and so any tutorials for the HD44780 will be very helpful. Unfortunately it has been a while since I needed to use an LCD so a bit rusty on the details.
Putting your code inside formats it better (sometimes)
You are in good company. And in some ways it is the only way we get to find out how things work.
That gives me enough to plug away. Thanks for the hints on posting code, as well.
Al
