AMC0802B LCD
I have a nifty little project I'm working on and thought it would be the perfect time to learn the Propeller. I found a decently priced little LCD that I would like to use instead of the serial lcd from Parallax due to size and cost. The C tutorials are pretty good but I am a little confused with SPI interfaces. I believe I can get the display initialized, but I can't figure out the best way to send the actual data to the display based on the datasheet. Do I send each individual character to the DDRAM address for its position in the display?
I have some experience with Stamps, but am completely new to the Propeller platform. I'm using SimpleIDE. I may have bitten off more than I can chew, but I tend to be a feet first kind of person.
Thanks!
Al
Oriental Display - AMC0802B-SPI
#include "simpletools.h" // Include simpletools lib
int lcd_csb = 6; // Chip Select
int lcd_sid = 7; // Data
int lcd_sclk = 8; // Clock
int lcd_rs = 9; // Register Select
int main() // Main function
pause(42); // Wait at least 40ms
high(lcd_csb); // CS line high
high(lcd_sclk); // CLK line high
low(lcd_csb); // CS -> low start SPI
pause(10);
//Initialize LCD
shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00111000); // Function Set - 8bit, 2 Line, 5x8
pause(1); // Wait at least 100us
shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00001100); // Display On
shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00000001); // Clear Display
pause(12); // Wait at least 10us
shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00000100); // Entry Mode Set
pause(1);
high(lcd_csb); // CS -> high stop SPI
pause(10);
//Send it a Character
shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b11000000); //Set DDRAM Address
shift_out(lcd_sid, lcd_sclk, MSBFIRST, 8, 0b00010100); //Generate "A"
Thanks!
Al
Hi
In answer to your question about character placement - Yes.
The AMC0802B is HD44780 compatible and so any tutorials for the HD44780 will be very helpful. Unfortunately it has been a while since I needed to use an LCD so a bit rusty on the details.
Putting your code inside formats it better (sometimes)
You are in good company. And in some ways it is the only way we get to find out how things work.
That gives me enough to plug away. Thanks for the hints on posting code, as well.
Al
