Will the propeller pins handle 3.7v?
I'm hooking the propeller up to a Adafruit power boost 1000 breakout board. It has a nice low power pin that is initially set high to the battery voltage, in my case a LiPo 3.7v battery. Once the battery voltage falls to 3.2 volts the pin is set low. Will hooking this pin up to the propeller cause problems? Should I put a resistor in series with it? Thanks,
Jason
https://learn.adafruit.com/adafruit-powerboost-1000-basic
Jason
Just use a series resistor of around 100k into the Prop pin as you don't want to affect the base of the digital PNP on that board. It's a matter of limiting current that's all and in this case not affecting the PNP that drives the LBO LED.
Though I'm wondering why you need to boost a 3.7V battery up to 5.2V to drop it back down to 3.3V unless of course you need 5V elsewhere.
Jason
