Print your own PC board with SM Reflowing? Wow
https://www.kickstarter.com/projects/voltera/voltera-your-circuit-board-prototyping-machine
"Print your circuit boards, dispense solder paste, and reflow! The Voltera V-One lets you go from concept to creation in minutes."
I would love to have one of these! Unfortunately the lead time is next year. Only does 2 layer boards, at the moment, but I don't see why it could not do multilayer boards with large area printing of the non-conductive layers as well as having a head that does PCB drilling for thru-hole parts.
PCB prototyping is going to get really exciting over the next few years as this type of thing takes off.
This with that Altera Max 10 chip sets would make for some interesting P1V board variants!
I hope these guys can make a go of it. I might even buy one once they're in production. But I've got to see something better than what my former supplier used before I'm convinced.
The solder paste dispensing would be tricky, any change in paste consistency and you would over/under deposit. Same would be true with the conductive ink. Fine traces might be an issue as well as any surface contaminant that would prevent it from properly sticking.
But then a lot of those same issues were there with the 3d extrusion printers and creative people have, mostly, found ways to make them reliable(ish).
